#1 2022-06-21 14:26
medianjoe
How to remove Template & Public folders?
I'm using Trinity and would like to remove the Template & Public folders from the home folder, but when I try to delete them they immediately reappear. I was able able to do this in previous versions of q4os. Is is possible and how to do it? Thanks.
#2 2022-06-22 10:38
Re: How to remove Template & Public folders?
You need to edit $HOME/.config/user-dirs.dirs and $HOME/.configtde/user-dirs.dirs and then remove the folders.
#3 2022-06-22 16:32
medianjoe
Thanks!
#4 2022-06-22 16:42
medianjoe
I removed references to those two folders in the files you mentioned and logged out, but it hasn't changed anything. When I try to delete the folders they reappear.
I tried both from the command line and TDE file manager.
#5 2022-06-22 19:29
I am using Plasma and It appears that a file user-dirs.dirs also exists in $HOME/.configkde/
Maybe the file you need to edit is in .configtde ... ?
#6 2022-06-23 08:27
medianjoe
Hi hchiper, thanks but q4os team already told me that I need to edit the file user-dirs.dirs in .configtde, which I did. I deleted the lines
XDG_PUBLICSHARE_DIR="$HOME/Public"
XDG_TEMPLATES_DIR="$HOME/Templates"
from BOTH user-dirs.dirs files in .config and .configtde, but when logging in these two lines are being appended to the file in .configtde, and I cannot delete the folders.
Is this a bug?
#7 2022-07-01 10:33
#8 2022-07-06 08:25
medianjoe
Thanks, but that didn't work either.
#9 2022-07-07 13:54
