#1 2022-03-24 00:42
Nik31415
I dont understand how to add a Wifi-Connection (Maybe im just stupid)
Hello
I just installed Q4OS(the newest live-version) and I only have "Wired Connection 1" available as a Network.
If i click on the "+" in Network Settings, i can select "Wi-Fi", but then i dont get a list of available Networks(like i read in other posts).
It opens up this window:
Window
And if I enter the SSID, select "WPA2 Personal" under Security and type in my Password, nothing happens.
Hope someone knows whats going on, because i dont :c
#2 2022-03-24 06:15
Re: I dont understand how to add a Wifi-Connection (Maybe im just stupid)
Either left-click on the network icon in the taskbar (beside the clock) to choose one of the detected WiFi in the list or use the application launcher ("start" button), choose System configuration and select Network / Connections in the list on the left and select your WiFi network in the list. In both cases I can see a list of available networks.
#3 2022-03-24 12:17
It sounds as if your wifi is not supported out of the box - did it work when you booted the live medium for installation?
Please run inxi -F
Copy and paste output.
#4 2022-03-25 08:51
moonoverhills
if you run a machine with wifi in it and cable like i do , your wifi is connected direct after install q4os , if you have inside your machine and you are use cable , and click on the connection button you wil alse see all the wifi connections , if not you have no wifi inside your machine
tip - if you have install q4os and you have wifi and cable on the machine , after installation of q4os the wifi drivers for your machine if there is wifi on it are allready install , and you can switch from cable to wifi direct , you wil see your name in the list allready , all you have the do is connected to your name and inter your password form your provider.
#5 2023-08-30 08:48
acerspanish
Hi, I have a similar issue, but in my case, I can see the wireless connections available and I can see my own wi-fi internet connection, but when I select the option, both of them, because I don't know why, I can see 2 options of my router, I get an error message from TDENetworkManager, which I suppose is the application that handles the wireless connections and the error message is: "Connection attempt failed! SSDI not found." and as I read the beginning of this post, I could see what is the first step I have to make which is to run the inxi - F command and I did and this is the result, of course I deleted the information of the mac code:
System:
  Host: q4os-desktop Kernel: 6.1.0-11-686-pae arch: i686 bits: 32
    Desktop: Trinity v: R14.1.1 Distro: Q4OS 5.2.1-n1
Machine:
  Type: Other-vm? System: Acer product: AO751h v: N/A
    serial: <superuser required>
  Mobo: Acer model: JV11-ML serial: <superuser required> BIOS: Acer
    v: 0.3208 date: 08/10/2009
Battery:
  ID-1: BAT1 charge: 1.9 Wh (90.5%) condition: 2.1/57.7 Wh (3.7%)
CPU:
  Info: single core model: Intel Atom Z520 bits: 32 type: MT cache:
    L2: 512 KiB
  Speed (MHz): avg: 798 min/max: 800/1333 cores: 1: 798 2: 798
Graphics:
  Device-1: Intel US15W/US15X SCH [Poulsbo] Graphics driver: gma500 v: N/A
  Device-2: Suyin Acer/Lenovo Webcam [CN0316] type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 1.21.1.7 driver: X: loaded: modesetting
    unloaded: fbdev,vesa dri: swrast gpu: gma500 resolution: 1366x768~60Hz
  API: OpenGL v: 4.5 Mesa 22.3.6 renderer: llvmpipe (LLVM 15.0.6 128 bits)
Audio:
  Device-1: Intel US15W/US15X/US15L/UL11L SCH [Poulsbo] HD Audio
    driver: snd_hda_intel
  API: ALSA v: k6.1.0-11-686-pae status: kernel-api
Network:
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac:
  Device-2: Qualcomm Atheros AR9285 Wireless Network Adapter driver: ath9k
  IF: wlp3s0 state: down mac:
Drives:
  Local Storage: total: 149.05 GiB used: 7.16 GiB (4.8%)
  ID-1: /dev/sda vendor: Hitachi model: HTS543216L9SA00 size: 149.05 GiB
Partition:
  ID-1: / size: 144.71 GiB used: 7.1 GiB (4.9%) fs: ext4 dev: /dev/sda1
Swap:
  ID-1: swap-1 type: partition size: 976 MiB used: 56.8 MiB (5.8%)
    dev: /dev/sda5
Sensors:
  System Temperatures: cpu: 34.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 161 Uptime: 9m Memory: 988.2 MiB used: 644.5 MiB (65.2%)
  Shell: Bash inxi: 3.3.26
I hope you can help me,  bin. Thank you  very much in advance for your help.
