It does exactly what i need it to do (Download videos without re-compression) but i want to use it on other distros aswell
Sorry, I'm new here and don't know how to start new question so I write here my question: is the YouTube downloader still available?
I have it listed in my "software center" but if I try to install it the warning appear stating that "Unable to download .... Check your internet connection", but for other apps it works normally, so it is not an issue...
I would be grateful if somebody could helps me?
I have looked in Q4OS 4 and 5 and none of them has "YouTube downloader" listed in Software Center. Which version of Q4OS do you use?
Anyway, if I remember well, youtube-dl doesn't work anymore (due to modifications inside YouTube). Instead you might use yt-dlp.
A GUI is also available separately. I've never used it.
yes, it is the way to go. The gui is well done by the way, but I prefer this one :
https://github.com/mhogomchungu/media-downloader
which is a GUI front end to yt-dlp, gallery-dl, lux, you-get, svtplay-dl, aria2c, wget and safari books
@wojan
What install file did you download to install Q4OS ?
Thank you very much to everyone
Im rather begginer and dont know-how How to check the version, but it is not the newest one. Probably 3xxx.
I installed the Media downloader and it works nice.
The GUI for yt-dip, Given by hchiper I wasnt able to install, commands given in the linked instruction didnt work with my Q4os ?
But Media downloader is OK, so once again thanks everybody ?
