#1 2022-02-16 20:57
tazmo8448
SHA512SUM for Q4OS 4.7.1 64bit Trinity
I would like to know where to get the sha512sum to verify the iso I have for the above mentioned distro. Being new to this also are there any tutorials showing how to go about doing this.
#2 2022-02-16 21:08
Re: SHA512SUM for Q4OS 4.7.1 64bit Trinity
There is md5sum of all the Q4OS images available on the downloads page https://www.q4os.org/downloads1.html . You need to scroll down to bottom of the page to see checksums.
#3 2022-02-17 01:44
tazmo8448
thanks for your timely replay. I did find out that and gtkhash works well on my daily driver Mint 19.1 to check it with; did find the md5sum and it did verify the q4os. in doing so found there are no other 'checks' as far as sums go so I guess that will have to do as there are no others to cross check.
hopefully down the road they'll be more sums, but as this is a distro not being as popular as others (fingers crossed) it may not be as necessary as the more popular versions. you know the ole low hanging fruit deal.
as a side note q4os has been a joy to deal with.
thanks again.
#4 2022-02-17 01:45
tazmo8448
color this one 'solved'
