How to fix it?
Kmixer capture etc already active
Using pulse & or intel, has the same result, no sound from external microphone. Just recorded from internal mic.
Please read this: https://www.q4os.org/forum/viewtopic.php?id=3502
And provide necessary information.
I installed the q4os gemini iso
On asus x201ev 1.6 ghz Intel Celeron with Hardisk
Full TDE package profiler
According to this review, your notebook has microphone/headphone combo jack.
And in ASUS support page is written, that if you want to use the external microphone function, the three-conductor 3.5 mm microphone will not work after plug into the Notebook audio combo jack.
So, consider to use a four-conductor 3.5 mm headphone with microphone device.
Also, you can try 3.5 mm Splitter cable, like this one: https://www.amazon.com/Kingtop-Adapter- … =8-19&th=1
I have been using these headphones for 6 months, and I am very happy with them.
