#1 2016-02-13 12:29
How often does Q4os check for updates
Hi all, I was wondering how often q4os is set to check for updates by default, and is it different for Orion/Scorpion?
Dai
#2 2016-02-13 16:43
Re: How often does Q4os check for updates
My guess is it would run on some sort of schedule, I haven't checked everywhere cron/apt/dpkg logs etc but i thought some one would know. I was just wondering if I left a system on 24/7 how often it would check by default. I know I can install cron-apt and configure /etc/cron.d/cron-apt to fix a schedule how I would like it, but if the system already checks at adequate (for my requirements) intervals I would not need to do anything, which is my usual preferred option smile
Dai
#3 2016-02-13 19:29
I figured as q4os full desktop profile has update notifier enabled by default there would be a scheduled update, but I could be wrong.
Dai
#4 2016-02-13 23:28
Apt software database is updated on 24h/daily basis. If you miss an update, it is performed a moment after the next boot.
#5 2016-02-14 00:57
Thanks again @q4osteam, I still couldn't figure it out so that cleared it up for me.
Dai
#6 2016-02-14 14:06
You must be special CC smile
Dai
