When I change the font size or open a new tab in LXTerminal 0.3.2 the window spontaneously resizes to unusable dimensions. When I change the font size the window shrinks horizontally so that it is just wide enough to display the menu bar. When I add a tab it shrinks vertically to show just a couple of lines in the window. It allows me to drag the window boundaries out but when I release the mouse button it immediately snaps back to the size it was.
The exact same version on a Raspberry Pi is perfectly well-behaved.
What am I missing?
Roy
To clarify, by Raspberry Pi I mean Raspbian 10 (buster)
Not able to reproduce this in TDE.
Please could you run inxi -F then copy and paste output in between
System: Host: q4os-desktop Kernel: 4.19.0-16-amd64 x86_64 bits: 64 Desktop: Trinity R14.0.6
Distro: Q4OS 3.14.2-n1
Machine: Type: Vmware System: VMware product: VMware Virtual Platform v: N/A serial: <root required>
Mobo: Intel model: 440BX Desktop Reference Platform serial: <root required> BIOS: Phoenix v: 6.00
date: 07/02/2015
CPU: Topology: 2x Single Core model: AMD FX-4350 bits: 64 type: SMP L2 cache: 4096 KiB
Speed: 4200 MHz min/max: N/A Core speeds (MHz): 1: 4200 2: 4200
Graphics: Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.15.0.0
Display: x11 server: X.Org 1.20.4 driver: vmware unloaded: fbdev,modesetting,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: llvmpipe (LLVM 7.0 128 bits) v: 3.3 Mesa 18.3.6
Audio: Device-1: Ensoniq ES1371/ES1373 / Creative Labs CT2518 driver: snd_ens1371
Sound Server: ALSA v: k4.19.0-16-amd64
Network: Device-1: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge driver: N/A
Device-2: Intel 82545EM Gigabit Ethernet driver: e1000
IF: ens33 state: up speed: 1000 Mbps duplex: full mac: 00:0c:29:b3:d1:69
Drives: Local Storage: total: 100.00 GiB used: 14.74 GiB (14.7%)
ID-1: /dev/sda vendor: VMware model: Virtual S size: 100.00 GiB
Partition: ID-1: / size: 89.80 GiB used: 14.62 GiB (16.3%) fs: ext4 dev: /dev/dm-0
ID-2: /boot size: 235.3 MiB used: 91.3 MiB (38.8%) fs: ext2 dev: /dev/sda1
ID-3: swap-1 size: 8.00 GiB used: 34.5 MiB (0.4%) fs: swap dev: /dev/dm-1
Sensors: Message: No sensors data was found. Is sensors configured?
Info: Processes: 194 Uptime: 2d 21m Memory: 7.77 GiB used: 1.07 GiB (13.8%) Shell: bash inxi: 3.0.32
VMWare - adds a bit of complication
Suggest you burn to USB, boot off USB and then install lxterminal via command line.
See what happens.
No need to mess about with USB sticks. I have the exact same software installed on bare metal. The problem reproduces exactly as on the VM.
FYI:
System: Host: loathing Kernel: 4.19.0-13-amd64 x86_64 bits: 64 Desktop: Trinity R14.0.6
Machine: Type: Desktop Mobo: GIGABYTE model: MZBAYAB-00 v: 1.x serial: <root required>
UEFI [Legacy]: American Megatrends v: F9 date: 03/02/2018
CPU: Topology: Quad Core model: Intel Celeron U1900 bits: 64 type: MCP L2 cache: 1024 KiB
Speed: 1316 MHz min/max: 1280/2320 MHz Core speeds (MHz): 1: 1316 2: 1311 3: 1287
4: 1316
Graphics: Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display driver: i915
v: kernel
Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~50Hz
Audio: Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
driver: snd_hda_intel
Sound Server: ALSA v: k4.19.0-13-amd64
Network: Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter driver: rtl8723be
IF: wlp2s0 state: down mac: 80:c5:f2:48:46:01
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: b4:2e:99:5d:91:06
Drives: Local Storage: total: 111.80 GiB used: 4.83 GiB (4.3%)
ID-1: /dev/sda vendor: Western Digital model: WDS120G2G0A-00JH30 size: 111.80 GiB
Partition: ID-1: / size: 101.77 GiB used: 4.83 GiB (4.7%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 7.89 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 65.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info: Processes: 174 Uptime: 146d 22h 54m Memory: 7.69 GiB used: 880.1 MiB (11.2%)
We can confirm and reproduce the issue. We will investigate that and post back.
The issue looks to be upstream Trinity bug, as it's reproducible on vanilla Trinity/Debian stable system too. It depends on the GTK3 applications theme configuration. You can easily workaround the bug changing the GTK theme in the "$HOME/.configtde/gtk-3.0/settings_trinity.ini", set the line "gtk-theme-name=Adwaita" . If you use for example "Breeze" theme, the terminal behaves exactly the way you have described. We consider this issue as upstream bug, so reporting for Trinity developers would be helpful.
Is that something I need to do?
No, however you can:
1. workaround the issue to suppress that on your system, see above
2. report a bug for upstream Trinity developers http://trinitydesktop.org/
