#26 2021-04-14 21:36
macg143
Re: Desktop profiler failed after fresh install on 32bit i386 Via EPIA
Hi q4osteam
sounds like a good Idea, I will bring it to work and see what happens.
thank you
#27 2021-04-16 01:54
macg143
Hello q4osteam
I took the pc to work and the symptoms were the same sad
What's interesting is that when I got home  I was able to install MX-tools using qrepoadd as explained in Tips & Tutorials, strange!
For whatever reason the profiler won't run because it thinks there's no connection  to the net!
thanks
#28 2021-04-16 08:40
@macg143
Thank you for the valuable information. We consider the issue as a serious one, and we would need to reproduce it as close as possible. It would be helpful, if you send us a relevant debug info. Please login as the first user and run in terminal:
$ reportq4
and send the debug file generated via email support@q4os.org , or attach it here for us to analyze.
