Glad to see you did it.TDE has so much more options to customize desktop than WinOS. I have not used my WinOS partition in over 2 weeks shooting for "FOREVER" !
No Longer Using Q4OS
Actually, It didn't take alot. The start button you see in the pic is actually the panel background.The TDE button is invisible.
That's cool - another option to do.
Yeah, that was the easiest option for me
No cc, it is, look at all the different ways we learn in TDE to create "unique" Start Button
If it wasn't for bobby, I would've never got the idea to do that.
@bobby
I found this http://www.webupd8.org/2012/11/how-to-c … -lock.html to change the login wallpaper. What do you think about it.
@bobby
I am not sure, not the one to ask about this.
I am keeping all core files as they are on everything I build so there is no compatibility issues with updates, etc.
I will look farther in to the TDE files next week and see if I can decipher a script to replace the login background.
Okay. Thanks!
