#51 2016-02-05 01:10
bobby
Re: A more Windows like start menu?
Glad to see you did it.TDE has so much more options to customize desktop than WinOS. I have not used my WinOS partition in over 2 weeks shooting for "FOREVER" !
No Longer Using Q4OS
#52 2016-02-05 01:15
ThisGuy1996
Actually, It didn't take alot. The start button you see in the pic is actually the panel background.The TDE button is invisible.
#53 2016-02-05 01:35
bobby
That's cool - another option to do.
#54 2016-02-05 01:43
ThisGuy1996
Yeah, that was the easiest option for me smile
#55 2016-02-05 03:19
bobby
No cc, it is, look at all the different ways we learn in TDE to create "unique" Start Button smile
#56 2016-02-05 05:44
ThisGuy1996
If it wasn't for bobby, I would've never got the idea to do that.
#57 2016-02-05 06:16
ThisGuy1996
@bobby
I found this http://www.webupd8.org/2012/11/how-to-c … -lock.html to change the login wallpaper. What do you think about it.
#58 2016-02-05 07:21
bobby
ThisGuy1996 wrote:
@bobby
I am not sure, not the one to ask about this.
I am keeping all core files as they are on everything I build so there is no compatibility issues with updates, etc.
I will look farther in to the TDE files next week and see if I can decipher a script to replace the login background.
#59 2016-02-05 07:24
ThisGuy1996
Okay. Thanks!
