#26 2016-02-03 00:14
bobby
Re: A more Windows like start menu?
@ThisGuy1996,  I lost where you left off (I do that a lot).  What did you install ?
No Longer Using Q4OS
#27 2016-02-03 00:20
ThisGuy1996
I installed KDE4 plasma. Out of curiosity, which version has the most customization options?
#28 2016-02-03 00:29
bobby
Oh, I don't know any thing about KDE 4 plasma. that have to be others.
#29 2016-02-03 04:49
ThisGuy1996
Yeah, I'm confused too. All I wanted to find a windows like start menu. Similar to gnomenu, but I can't get that to work.
#30 2016-02-03 04:55
ThisGuy1996
I have, yes. But I like the XP gui better. Do you know how to properly install gnomenu?
#31 2016-02-03 05:09
ThisGuy1996
From what I dug up, there is a Debian Jessie package but needs some dependencies. I installed it successfully but it didn't not show up in the "Add applet to panel" settings.
#32 2016-02-03 06:19
ThisGuy1996
Yeah, I won't mess around with changing the start menu. I know this is off topic, but do you know how to change the kickoff menu icons? For example, I want to change the recent tab to a different icon, or the leave icon to something else. Sorry to waste your time, I'm a complete noob to all this. Thanks for all your help.
#33 2016-02-03 08:12
bobby
I have learned more about Q4OS (Linux) in the last 3 months then the last 15 years of using it off & on. I still consider myself a noobie too,
But, GOOD News  on you Start Button Request. Its Green - Its Size Right with Black text only.
Will this work ?
If so, I will post a how to  but basically its 3 different pages you have to make changes to get this effect in TDE.
#34 2016-02-03 08:14
bobby
@ThisGuy1996,
Will this work ?
_____________________________
GREAT NEWS !
THIS IS XPQ4  using the "XP Luna" option:
#35 2016-02-03 14:24
ThisGuy1996
Perfect! Post whenever you can.  Thanks!
#36 2016-02-03 20:47
bobby
cc is right.  XPQ4 with Luna selected is best choice.   I will work on a tutorial over the next few days and post here.
#37 2016-02-03 23:48
ThisGuy1996
Yeah, i'll stick with XPQ4. Post whenever you can work on it. Thanks!
#38 2016-02-04 00:29
ThisGuy1996
@bobby
About that "start" button, was the green button background custom? If that was, that's awesome. Also, will I still keep the panel background  the XP luna image like this shown below?
#39 2016-02-04 00:42
bobby
@ThisGuy1996
The two destops under - THIS IS XPQ4  using the "XP Luna" option:
are 100% configured via TDE Menu & taskbar settings.  The windows logo to the left can be changed too.
I'm under the weather and behind on some work. I'd install the XPQ4 application and switch it to Luna as most of its already done.
If you have any questions I'll be here off and on for next 2 days.
#40 2016-02-04 00:48
ThisGuy1996
Okay, hope you feel better soon!
#41 2016-02-04 03:45
ThisGuy1996
Just one more question. Does anybody know how to make the start icon(circled in red in the pic attached) slightly bigger without making the rest of the panel bigger?
#42 2016-02-04 05:44
bobby
cc, Final update to my wicked Avatar is also my Final logo code name, "Q4 Live".  the internal outline is a ghost fashioned similar to LinPin smile
I know its plain Jane stuff but, when I get a few extra bucks I see if I can get it "Professionally Remastered".
#43 2016-02-04 06:00
bobby
@ThisGuy1996
I tried for a long time last night to increase the Menu Icon and it can only be done when you increase all taskbar icon size. Some discussion on web that if you do change it in the Theme files, you have to do this for every Theme but, I have not verified if its possible at all.
But, I was able to do this:
Play direct to VLC, etc.=  http://q4live.com/videos/misc/xpq4-start-button.mp4
Play on youtube =  https://www.youtube.com/watch?v=Wn0UFQPBrEM
#44 2016-02-04 06:06
ThisGuy1996
How were you able to do this?
#45 2016-02-04 06:20
bobby
Right click Taskbar --> Configure Panel --> click Appearance (left side) --> Under General place check mark in "Enable icon mouseover effects" = Apply or Ok
_-------
If you enable "Enable icon activation effects" = when you click on a Desktop icon flashes larger for a second for a cool launch indication.
#46 2016-02-04 06:42
ThisGuy1996
Cool. One more question, then i'll leave you alone. Do you know how to change the login background?
#47 2016-02-04 06:54
bobby
I have been working on that for a week now. have not found out. I hear the secret location is on a list under the Q4OS lead developers pillow smile
Seriously though, I have been looking for how to change. It did change once with a theme change so, it must be in Trinity /opt/....  I take a look at it again tomorrow.
I do want to thank you @ThisGuy1996 as if you had not asked about modiding the Start button I would not had found the ability to add text to it. It was obvious as heck too.  Now I will brand every Linux boot that I have, pure, basic, desktop, MyLiveOS Lite, Systemback, Q4 Live, and on and on.
#48 2016-02-04 07:11
ThisGuy1996
No, thank you for taking the time out to help me. I really do appreciate that.
#49 2016-02-04 07:18
bobby
Your Wecome - Anytime. Now off to sleep I go to feel better tomorow, I pray.
Rev. Bobby
#50 2016-02-04 23:39
ThisGuy1996
I figures how to get the start button I wanted! Take a look.
Edit. I don't know why its a bin file.
