#1 2019-12-20 19:11
habs2habs
please help,i can not install Q4OS
Hi everyone
i am new to Q4OS,i am installing this operating system alongside windows 10 as dual bootup.
when i tried to install Q4OS nearly in the end,an error open up:
installation failed
Bad unsquash  configuration
The source filesystem "/run/live/medium/live/filesystem.squashfs" does not exist
if i leave to Q4OS which on DVD drive,the Q4OS works fine,but when i tried to install the Q4OS this error come up.
can you help me please
thank you
#2 2019-12-20 20:49
Re: please help,i can not install Q4OS
That looks like damaged installation media, or did you unmount install media some way ?
#3 2021-03-02 11:51
davemx
This happened to me several times with 4.10, and again with 4.14, but yesterday I got q4os installed. The difference was that I created the installation media using the "dd" command, on its own USB stick. Previously I had used a program called multibootusb to create a boot medium holding several distros, and all the others installed from that.
When I tried to search the internet I saw this complaint lots of times, on this forum and elsewhere, but no solutions.
Well the solution is use dd or a front-end for dd, and not use a multi-boot medium. I don't know why q4os won't install of such a medium, but this is the answer!
#4 2021-03-02 11:53
Thanks for the report, we will take a look on that.
#5 2021-03-11 17:42
What Multiboot version and what host system did you use ?
#6 2021-04-20 09:19
ninux
Do you think it depends on the Version? I have the 9.2.0 and host system Peppermint Os 10.
whatever boot of ISO (other distro too) I copied on the USB key, if it worked, freezed or failed installation.
Thank you for the suggestion, i think should be multiboot that is not well supported.
I burned my key with unetbootin and everythings works!!
Now I have an old EEEPC with 512mb RAM, CPU atom N450 perfectly working, with a system similar to Windows that starts in a min.
THANK YOU.
vote 10!!
