#1 2019-07-29 00:06
cjoliprsf
Stopping the clock
As I am building a minimal virtual machine to run Linux programs on a Windows machine, I don't need to have a clock in this VM. Hence wondering if there is a way to remove it (and prevent it from starting)
Also I have the sound mixer that keeps on being there even if I try to close it - the VM has no sound card, so it is a bit ridiculous to have this mixer on the bar.
And if there are other unrequired things or services that I could take off to make the VM as light as possible, I have my ears wide open!
System is Q4OS 2.7 in 32 bits.
Thanks
Claude
#2 2019-07-30 14:54
Re: Stopping the clock
You mean just remove the clock from the taskbar?  You can't actually STOP the clock from a low-end level, as the OS does indeed require it to function.
#3 2019-07-31 09:19
The clock can not be stopped. They are required for kernel to function properly.
#4 2019-07-31 15:54
cjoliprsf
Indeed I was mostly surprised that I couldn't remove the clock from the taskbar - most other things are removeable.
But I can live with it - this is no real problem.
However if there are other services that are started at boot, require some memory, and aren't absolutely necessary in a virtual machine (for example sound drivers), then I'd like to be able to prevent these from starting.
Is there a way? Is there a script somewhere that specifies what is started at boot that I could edit?
Since this is a VM, I can make a snapshot before playing with it, and if I break something, I can easily go back to previous state...
Thanks
#5 2019-07-31 16:58
cjoliprsf wrote:
Indeed I was mostly surprised that I couldn't remove the clock from the taskbar...
Mouse right click on the systray > Configure system tray > uncheck "Show clock in tray"
#6 2019-07-31 18:03
cjoliprsf
Actually, this doesn't work... It is already unchecked. If I check it, I then get 2 clocks side by side!
#7 2019-07-31 19:16
So, let it unchecked and remove clock applet from panel.
Mouse right click on the system panel > Unlock panels > Mouse right click to the system panel again > Remove from panel > Applet > Clock > Optionally lock the panel again.
We can also recommend you to install Lookswitcher and switch to the "Wine_Classic" theme. It will lower memory and system requirements significantly. Comparable by "htop" application.
#8 2019-07-31 19:39
cjoliprsf
Thanks for the tips! Works nicely.
