#1 2019-07-16 18:07
k3b-trinity icon is absent
Good evening!
I have installed k3b-trinity package, but after installation, I can not find it's icon on Start menu.
I searched manually, searched using search bar - no success...
https://drive.google.com/file/d/1-dx0g6 … sp=sharing
https://drive.google.com/file/d/1-h29YK … sp=sharing
I was able to launch k3b-trinity using Alt+F2. So, the application was installed successfuly.
https://drive.google.com/file/d/1-Zuz9Q … sp=sharing
Also, there is old icon in application install wizard.
https://drive.google.com/file/d/1-Y8MV_ … sp=sharing
#2 2019-07-17 11:13
Re: k3b-trinity icon is absent
K3b-trinity suffers from a few bugs, we recommend to use another burning software. We are not able to remove it completely from repositories due to dependencies at the moment, it should be done in a future. The install wizard icon rework is already on our todo list. Thanks for reporting.
#3 2019-07-17 14:21
Which burning software can you recommend?
#4 2019-07-17 14:43
K3b .. from KDE suite
Brasero .. GTK application, lightweight and easy to use
#5 2019-07-22 14:43
I used Brasero before... It made six my brand new Taiyo Yuden DVD discs unreadable! mad Also, I have read on forums, that it made unreadable another users DVD discs too.
So, I switched to XfBurn. What about it? Does it works well on Q4OS?
#6 2019-07-22 15:39
You should be fine with XfBurn. As far as we know, it's a reliable burning application, although we haven't tested it in Q4OS.
#7 2019-10-30 21:15
cpcnw
Has development stopped on the Trinity version? Using k3b from KDE adds 100mb as opposed to 35mb
