#1 2019-06-25 00:31
danielson
Can Windows installed version be easily removed?
Just curious (hoping no one else already asked).
DELL Optiplex 7060 - 8G RAM.
#2 2019-06-25 09:02
Re: Can Windows installed version be easily removed?
I'm having to go from memory here (haven't installed from Windows in a long time) but is there an uninstall or remove option from the Windows installer? That is if you run the installer again (from Windows) does it give you this option?
#3 2019-06-25 11:17
danielson
That is the question.
#4 2019-06-25 11:27
So you haven't tried?
#5 2019-06-25 12:25
I just installed Q4OS for Windows and rebooted (back into Windows) and ran the installer again and it has to remove the previous installation first (after you confirm) and then if you do not want Q4OS from windows installer you click cancel and it will finish, the result is bootloader entries removed and the Q4OS installation is also removed.
So the short answer is yes it can smile
#6 2019-06-25 16:29
danielson
Excellent new Dai_trying!!
Verrrry gooood! smile
#7 2019-06-25 16:31
Please read the documentation https://www.q4os.org/dqa014.html , chapter 5. Uninstallation
#8 2019-06-25 17:02
As usual there is an easier way to find out big_smile
#9 2019-06-25 18:40
danielson
That's no fun! wink
Thanks Q4OS Team.
#10 2019-06-30 17:19
danielson
Well, i finally got to installing 2.7 and everything ran as expected (Legacy PC).
Is it possible to "upgrade" to latest test version?
#11 2019-06-30 17:57
No, we don't recommend to do Scorpion > Centaurus upgrade, although you could try to follow a common Debian Stretch > Buster upgrade instructions on your own. You should do Q4OS 3 Centaurus clean installation, https://www.q4os.org/downloads2.html
#12 2019-06-30 19:27
danielson
I understand.
It's already a pretty good thing to have a kind of WUBI installer with a solid distro to work with!
