#1 2019-04-21 08:19
sudoluna
How to modify Login screen to make it look like XP
Tryna make Q4 look like a replica of XP. Would also like to know how to get the side drop on the bottom right to look as authentic as possible.
#2 2019-04-21 11:39
jessexschilling
Re: How to modify Login screen to make it look like XP
might want to check this project out:
https://xpq4.sourceforge.io
i have not used it, but it appears they have done the heavy lifting for you. Including all of the icons, fonts, and such.
Jesse Schilling | rainydayshirts
#3 2019-04-21 23:32
sudoluna
Yes, but this does not change the log-on screen. I'm looking to create a version of Q4OS that defaults to the XP look, so that users who want/stick with XP have a solid alternative. I need to recreate the complete experience though.
#4 2019-04-22 08:02
If you have not already done so, first open terminal - Konsole and type
sudo kcmodules --unlock
Then open control centre>system administration>login manager - click administrator mode
You can then alter
Appearance:-
Greeting - Q4OS Professional
Logo Area>Show Logo>/usr/share/icons/kde_windowsxp/48x48/apps/kmenu.png - for example
GUI Style>Plastik
Colour Scheme>Redmond XP
Apply
Font - Set all to Tahoma - Anti-alias OFF - I suggest you stick to size 8 or 10
Apply
Background - tricky - after a think I suggest /opt/trinity/share/apps/ksplash/Themes/Redmond/Background.png
Users - uncheck Show List
Apply
OK - it isn't perfect - but that's a starting point.
You might also want to go to control centre>tde components>session manager
General - uncheck all except Confirm Logout and Offer Shutdown Options
Default Shutdown Option set to Turn Off
If these are single user home machines then I would set them to automatic login - in which case most of this is only going to be seen once in a while anyway.
My advice - do not get too hung up on the fine details - a login box is pretty obvious in its purpose.
Other suggestions to provide a more familiar file explorer experience
Open My Documents
Press f9
Left hand side is a column of icons - NOT the folder tree.
Click the House - Home icon
That should give a tree view of the user home with folders in the right hand pane
Click Settings > Save view profile "File Management"
Hope this helps
#5 2022-04-01 18:24
Baloo
Has there been any updates to this involving the Login Screen? Would love to see if anyone has been able to make a very good recreation of the Windows XP login screen. I've managed to install Plymouth and find a comparable boot screen to Windows XP for anyone interested: https://github.com/Liftu/WindozeXP-1080 … enshot.png
baloo.neocities.org
