#1 2017-06-05 15:12
sfb2
"Package system busy" ?
hi there,
first many thx for this beautiful q4os..
i got this via berryboot-images..
have a permanent "package system busy" error..cant install anything..
how can i solve this problem ?
many thx in advance !!
#2 2017-06-05 15:31
Re: "Package system busy" ?
My guess is that there has been some changes to the original Q4OS image and we would not be able to troubleshoot your problem without finding out what they are.
My best suggestion would be to download the Q4OS Pi image and burn it to SD Card and try that to see if you get the same error, that is if you have a spare SD Card to try it.
I recently (a few days ago) was given an old Pi (original) with only 256Mb memory and a 700Mhz cpu but version 1806 runs fine and shows no update errors, in fact it runs surprisingly well considering the hardware it has to work with smile
#3 2017-06-05 15:34
@sfb2
The described issue is not normal in Q4OS. You could check which processes are blocking APT operations. Just run in terminal:
$ check-apt-busy
$ ps -ef
and post output here to analyze.
We can recommend you to follow Dai_trying's advice above as well.
#4 2017-06-05 16:32
sfb2
hi there,
many many thx for this ultra fast response !! great !!
check-apt-busy:
"cannot open lock file!
Unable to lock: /var/cache/apt/archives/lock
[CHKPKSYS] >> Package system status: Busy !" ;-)
ps -ef:
UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  0 14:02 ?        00:00:06 lib/systemd/systemd
root         2     0  0 14:02 ?        00:00:00 [kthreadd]
root         3     2  0 14:02 ?        00:00:00 [ksoftirqd/0]
root         5     2  0 14:02 ?        00:00:00 [kworker/0:0H]
root         7     2  0 14:02 ?        00:00:01 [rcu_sched]
root         8     2  0 14:02 ?        00:00:00 [rcu_bh]
root         9     2  0 14:02 ?        00:00:00 [migration/0]
root        10     2  0 14:02 ?        00:00:00 [lru-add-drain]
root        11     2  0 14:02 ?        00:00:00 [cpuhp/0]
root        12     2  0 14:02 ?        00:00:00 [cpuhp/1]
root        13     2  0 14:02 ?        00:00:00 [migration/1]
root        14     2  0 14:02 ?        00:00:00 [ksoftirqd/1]
root        16     2  0 14:02 ?        00:00:00 [kworker/1:0H]
root        17     2  0 14:02 ?        00:00:00 [cpuhp/2]
root        18     2  0 14:02 ?        00:00:00 [migration/2]
root        19     2  0 14:02 ?        00:00:00 [ksoftirqd/2]
root        21     2  0 14:02 ?        00:00:00 [kworker/2:0H]
root        22     2  0 14:02 ?        00:00:00 [cpuhp/3]
root        23     2  0 14:02 ?        00:00:00 [migration/3]
root        24     2  0 14:02 ?        00:00:00 [ksoftirqd/3]
root        26     2  0 14:02 ?        00:00:00 [kworker/3:0H]
root        27     2  0 14:02 ?        00:00:00 [kdevtmpfs]
root        28     2  0 14:02 ?        00:00:00 [netns]
root        29     2  0 14:02 ?        00:00:00 [khungtaskd]
root        30     2  0 14:02 ?        00:00:00 [oom_reaper]
root        31     2  0 14:02 ?        00:00:00 [writeback]
root        32     2  0 14:02 ?        00:00:00 [kcompactd0]
root        33     2  0 14:02 ?        00:00:00 [crypto]
root        34     2  0 14:02 ?        00:00:00 [bioset]
root        35     2  0 14:02 ?        00:00:00 [kblockd]
root        36     2  0 14:02 ?        00:00:00 [watchdogd]
root        38     2  0 14:02 ?        00:00:00 [rpciod]
root        39     2  0 14:02 ?        00:00:00 [xprtiod]
root        43     2  0 14:02 ?        00:00:00 [kswapd0]
root        44     2  0 14:02 ?        00:00:00 [vmstat]
root        46     2  0 14:02 ?        00:00:00 [nfsiod]
root        56     2  0 14:02 ?        00:00:00 [kthrotld]
root        58     2  0 14:02 ?        00:00:00 [bioset]
root        59     2  0 14:02 ?        00:00:00 [bioset]
root        60     2  0 14:02 ?        00:00:00 [bioset]
root        61     2  0 14:02 ?        00:00:00 [bioset]
root        62     2  0 14:02 ?        00:00:00 [bioset]
root        63     2  0 14:02 ?        00:00:00 [bioset]
root        64     2  0 14:02 ?        00:00:00 [bioset]
root        65     2  0 14:02 ?        00:00:00 [bioset]
root        66     2  0 14:02 ?        00:00:00 [bioset]
root        67     2  0 14:02 ?        00:00:00 [bioset]
root        68     2  0 14:02 ?        00:00:00 [bioset]
root        69     2  0 14:02 ?        00:00:00 [bioset]
root        70     2  0 14:02 ?        00:00:00 [bioset]
root        71     2  0 14:02 ?        00:00:00 [bioset]
root        72     2  0 14:02 ?        00:00:00 [bioset]
root        73     2  0 14:02 ?        00:00:00 [bioset]
root        74     2  0 14:02 ?        00:00:00 [bioset]
root        75     2  0 14:02 ?        00:00:00 [bioset]
root        76     2  0 14:02 ?        00:00:00 [bioset]
root        77     2  0 14:02 ?        00:00:00 [bioset]
root        78     2  0 14:02 ?        00:00:00 [bioset]
root        79     2  0 14:02 ?        00:00:00 [bioset]
root        80     2  0 14:02 ?        00:00:00 [bioset]
root        81     2  0 14:02 ?        00:00:00 [bioset]
root        82     2  0 14:02 ?        00:00:00 [iscsi_eh]
root        83     2  0 14:02 ?        00:00:00 [dwc_otg]
root        84     2  0 14:02 ?        00:00:00 [DWC Notificatio]
root        85     2  0 14:02 ?        00:00:00 [elousb]
root        86     2  0 14:02 ?        00:00:00 [VCHIQ-0]
root        87     2  0 14:02 ?        00:00:00 [VCHIQr-0]
root        88     2  0 14:02 ?        00:00:00 [VCHIQs-0]
root        89     2  0 14:02 ?        00:00:00 [bioset]
root        90     2  0 14:02 ?        00:00:00 [VCHIQka-0]
root        91     2  0 14:02 ?        00:00:00 [SMIO]
root        93     2  0 14:02 ?        00:00:00 [irq/92-mmc1]
root       101     2  0 14:02 ?        00:00:00 [bioset]
root       102     2  0 14:02 ?        00:00:00 [mmcqd/0]
root       109     2  0 14:02 ?        00:00:00 [scsi_eh_0]
root       110     2  0 14:02 ?        00:00:00 [scsi_tmf_0]
root       111     2  0 14:02 ?        00:00:00 [usb-storage]
root       112     2  0 14:02 ?        00:00:00 [bioset]
root       114     2  0 14:02 ?        00:00:00 [kworker/0:1H]
root       115     2  0 14:02 ?        00:00:00 [jbd2/mmcblk0p2-]
root       116     2  0 14:02 ?        00:00:00 [ext4-rsv-conver]
root       139     2  0 14:02 ?        00:00:00 [cfg80211]
root       141     2  0 14:02 ?        00:00:00 [brcmf_wq/mmc1:0]
root       142     2  0 14:02 ?        00:00:00 [brcmf_wdog/mmc1]
root       153     2  0 14:02 ?        00:00:00 [loop0]
root       158     2  0 14:02 ?        00:00:00 [kworker/2:1H]
root       159     2  0 14:02 ?        00:00:00 [ipv6_addrconf]
root       165     2  0 14:02 ?        00:00:00 [kworker/1:1H]
root       170     2  0 14:02 ?        00:00:00 [kworker/3:1H]
root       183     1  0 14:02 ?        00:00:00 /lib/systemd/systemd-journald
root       205     1  0 14:02 ?        00:00:00 /lib/systemd/systemd-udevd
root       471     1  0 14:02 ?        00:00:01 /usr/sbin/NetworkManager --no-da
root       473     1  0 14:02 ?        00:00:00 /usr/sbin/cron -f
root       475     1  0 14:02 ?        00:00:00 /usr/sbin/rsyslogd -n
root       477     1  0 14:02 ?        00:00:00 /usr/sbin/sshd -D
message+   479     1  0 14:02 ?        00:00:01 /usr/bin/dbus-daemon --system --
root       487     1  0 14:02 ?        00:00:00 /lib/systemd/systemd-logind
root       512     1  0 14:02 tty1     00:00:00 /sbin/agetty --noclear tty1 linu
nobody     521     1  0 14:02 ?        00:00:01 /usr/sbin/thd --daemon --trigger
root       523     1  0 14:02 ?        00:00:00 /opt/trinity/bin/tdm
root       530   523  1 14:02 tty7     00:01:21 /usr/lib/xorg/Xorg -br -dpi 96 -
root       534     1  0 14:02 ?        00:00:00 /usr/lib/policykit-1/polkitd --n
root       544     1  0 14:02 ?        00:00:00 /sbin/wpa_supplicant -u -s -O /r
root       545   471  0 14:02 ?        00:00:00 /sbin/dhclient -d -q -sf /usr/li
root       555   523  0 14:02 ?        00:00:00 -:0
root       557     1  0 14:02 ?        00:00:04 /opt/trinity/bin/tdekbdledsync
pi         713     1  0 14:02 ?        00:00:00 /lib/systemd/systemd --user
pi         716   713  0 14:02 ?        00:00:00 (sd-pam)
pi         719   555  0 14:02 ?        00:00:00 /bin/sh /usr/bin/x-session-manag
pi         754   719  0 14:02 ?        00:00:00 /usr/bin/ssh-agent /usr/bin/dbus
pi         757     1  0 14:02 ?        00:00:00 /usr/bin/dbus-launch --exit-with
pi         758     1  0 14:02 ?        00:00:00 /usr/bin/dbus-daemon --fork --pr
root       803     1  0 14:02 ?        00:00:00 /opt/trinity/bin/tde_dbus_hardwa
pi         809     1  0 14:02 ?        00:00:00 dcopserver [tdeinit] --nosid --s
pi         814     1  0 14:02 ?        00:00:03 kded [tdeinit] --new-startup
root       824     1  0 14:02 ?        00:00:00 start_tdeinit --new-startup +kcm
pi         825     1  0 14:02 ?        00:00:00 [tdeinit] tdeinit Running...
pi         828   825  0 14:02 ?        00:00:00 tdelauncher [tdeinit] --new-star
pi         840   719  0 14:03 ?        00:00:00 /opt/trinity/bin/tdeinit_phase1
pi         841   840  0 14:03 ?        00:00:00 sh -c kwrapper ksmserver
pi         842   841  0 14:03 ?        00:00:00 kwrapper ksmserver
pi         844     1  0 14:03 ?        00:00:01 ksmserver [tdeinit]
pi         845   825  0 14:03 ?        00:00:08 twin [tdeinit]
pi         847     1  0 14:03 ?        00:00:10 /opt/trinity/bin/kdesktop
pi         852     1  0 14:03 ?        00:00:30 kicker [tdeinit]
pi         853   825  0 14:03 ?        00:00:00 tdeio_file [tdeinit] file /tmp/t
pi         859     1  0 14:03 ?        00:00:00 kxkb [tdeinit]
pi         866   825  0 14:03 ?        00:00:04 /opt/trinity/bin/artsd -F 10 -S
pi         868     1  0 14:03 ?        00:00:00 kaccess [tdeinit]
pi         875   825  0 14:03 ?        00:00:00 /usr/bin/welcome-screen.exu --ic
pi         877     1  0 14:03 ?        00:00:01 knotify [tdeinit]
pi         881     1  0 14:03 ?        00:00:01 klipper [tdeinit]
pi         883     1  0 14:03 ?        00:00:00 kmix [tdeinit] -caption KMix -ic
pi         890     1  0 14:03 ?        00:00:03 tdenetworkmanager [tdeinit]
pi         992   825  0 14:04 ?        00:00:00 /bin/sh -c ( dash ~/.config/q4os
pi         995   992 27 14:04 ?        00:24:02 konqueror --profile webbrowsing
root      1324     2  0 14:21 ?        00:00:00 [kworker/1:2]
pi        1367   825  0 14:23 ?        00:00:01 konqueror [tdeinit] --profile ct
pi        1372     1  0 14:23 ?        00:00:00 tdeio_uiserver [tdeinit]
root      1373     2  0 14:23 ?        00:00:00 [kworker/2:0]
pi        1382     1  8 14:25 ?        00:05:44 ksysguard
pi        1383  1382  0 14:25 ?        00:00:00 /bin/sh -c ksysguardd
pi        1384  1383  4 14:25 ?        00:03:02 ksysguardd
pi        1391   825  0 14:26 ?        00:00:00 /usr/bin/swcentre.exu --icon swc
pi        1487  1384  0 14:27 ?        00:00:00 [ksysguardd] <defunct>
root      1619     2  0 15:07 ?        00:00:00 [kworker/u8:1]
root      1620     2  0 15:07 ?        00:00:00 [kworker/3:2]
root      1622     2  0 15:12 ?        00:00:00 [kworker/0:3]
root      1645     2  0 15:19 ?        00:00:00 [kworker/1:0]
pi        1650   847  0 15:20 ?        00:00:00 /opt/trinity/bin/kdesktop_lock -
root      1651     2  0 15:20 ?        00:00:00 [kworker/2:2]
pi        1652   825  0 15:20 ?        00:00:01 konsole [tdeinit]
pi        1653  1652  0 15:20 pts/1    00:00:00 bash
root      1660     2  0 15:20 ?        00:00:00 [kworker/u8:0]
root      1690     2  0 15:23 ?        00:00:00 [kworker/3:1]
root      1691     2  0 15:24 ?        00:00:00 [kworker/0:0]
root      1692     2  0 15:27 ?        00:00:00 [kworker/u8:2]
root      1700     2  0 15:29 ?        00:00:00 [kworker/3:0]
root      1701     2  0 15:29 ?        00:00:00 [kworker/0:1]
pi        1703  1653  0 15:30 pts/1    00:00:00 ps -ef
but many,many thx !!
(as u see, i really got no clue about it !! ;-) )
(but i´m really "falling in love" ;-) with this q4os->have "billions" of other Oses on my pi (solydxk,daylight linux,ubuntu mate etc.etc..) but this q4os is so nice ;-) )
gr..
#5 2017-06-05 19:13
This message means the key file ' /var/cache/apt/archives/lock' has incorrect permissions set, or it's missing completely in Berryboot image. We can only recommend you to use the official Q4OS RPi image, please see Dai_trying's post above. We will check the Berryboot image in a few days and post final result here.
#6 2017-06-05 19:33
sfb2
thx so much !!
(cause i really really like this q4os !!) ;-)
will download the image file here and try it as "standalone" !!
thx again ;-)
#7 2018-09-04 18:15
xyneodrew
I know that this is an old post but I was able to solve this issue as I have the same setup where I use Berryboot.
First time I loaded the q4os berryboot image I've got the same ERROR message "package system busy" whenever I try to install the Default Profiler. The solution was really easy:
On the first time you login, run the following into the terminal:
#sudo apt-get update
#sudo apt-get dist-upgrade
This will update all the packages...may time some time.
Once done, REBOOT! DO NOT install or setup anything yet!
On your next login, try to install the default profiler again.
