#1 2018-06-26 06:45
simstim
My Documents folder changes icon
I switched the icons on my Q4OS install to the Paper option and everything was working fine for a number of days. However, the My Documents folder has suddenly reverted back to the default Crystal icon. All the other icons have remained Paper.
I have tried changing the icons settings to default and then back to Paper, but the problem remains. Is there any way I can change just this one icon to Paper?
#2 2018-06-26 07:55
Re: My Documents folder changes icon
You could try to refresh the '.directory' file inside the Documents folder, so run in terminal:
$ kwriteconfig --file "$( xdg-user-dir DOCUMENTS )/.directory" --group "Desktop Entry" --key "Icon" "folder-documents"
logout / login and report back.
#3 2018-06-27 03:35
simstim
Thanks, that restored the correct icon.
