#1 2017-10-09 23:22
Q4OS Scorpion 2.4 Stable
Q4OS Scorpion becomes stable in version 2.4, please see release notes https://www.q4os.org/blog.html#news171010
Both, live media as well as installation media, are available for 64bit/32bit - x86/i386 systems.
#2 2017-10-11 00:52
Re: Q4OS Scorpion 2.4 Stable
Thanks for the installation media as Im going to put it to work right away.
#3 2017-11-06 05:05
rafaelramos
What is the meaning of the letters "r1", "r2"?
Is "release1", "release2"...?
#4 2017-11-06 08:11
Installation media revisions, not connected to OS version.
#5 2017-11-06 23:21
Installation media is excellent as Ive done many installs so far without problems.
#6 2017-11-07 04:15
rafaelramos
Another question: with the release of the stable version 2.4 of Scorpion, the old version 1.8 Orion is "discontinued"?
#7 2017-11-07 04:25
No, Orion is still supported for another 2+ years.
#8 2017-11-07 20:05
Orion is supported till May 2020.
#9 2017-11-07 20:53
rafaelramos
What about the kernel version of the Scorpion? Is it version 4.X or is it still version 3.X?
#10 2017-11-07 21:02
Kernel 4.9, as it's based on Debian Stretch.
#11 2017-11-07 21:22
You can use a newer kernel with Orion as I used 4.4 with it with no issues.
Scorpion though is one of the best installs Ive ever had, fast,stable no issues.
#12 2017-12-26 14:38
rafaelramos
The 2.4 Scorpion version is excellent! Great job guys!
Will you release version 2.4 for Raspberry Pi as well? Because the current version for RPi is still based on 1.8...
#13 2017-12-26 16:13
Yes, we will release Q4OS Scorpion for RPi as soon as Trinity developers https://www.trinitydesktop.org/ release Trinity DE for Raspbian Stretch.
#14 2018-05-06 17:14
So, we shall wait and hope...
#15 2018-05-16 14:55
rafaelramos
Good Morning,
The last release of Q4OS was version r9, now I noticed in the downloads section that the x86/x64 versions are named as "ra"... What does it mean? Should not it be version r10?
#16 2018-05-16 15:18
Installation media revisions will be marked as r1, r2, .., r9, ra, rb, .. etc., they are not related to the OS version, for example '2.4.8-n1'.
EDIT: You can check Q4OS version using terminal command:
$ get-q4os-version
#17 2018-06-25 22:44
rafaelramos
So far nothing of the TDE version for Raspbian Stretch...  sad
#18 2018-08-12 14:51
@rafaelramos
Q4OS Scorpion for RPi becomes stable now, please read https://www.q4os.org/blog.html#news180813
#19 2018-08-23 15:36
rafaelramos
Thats great! big_smile
