#1 2017-10-14 02:25
plg6
In-place upgrade or new install?
Good day,
I'm wondering - is there a way to do an in-place upgrade of Q4OS from 1.8.x to the new Scorpion version, or must one do a full reinstall? I haven't found a clear answer on this, hence the question.
Thanks in advance for your reply.
#2 2017-10-14 10:31
Re: In-place upgrade or new install?
The advice offered from the devs in another post recommended doing a fresh install, I think this advice is best practice although simply updating your sources might perform an upgrade ok but I always do a fresh install, it's better to be safe than it is to be sorry smile
#3 2017-10-14 11:01
Chandler Gomez
Hello plg6.
The best option is a new installation and is recommended for developers.
I always reinstall the new version.
Sorry for my bad English.
#4 2017-10-14 17:22
Many issues doing an in place upgrade, definitely fresh install.
