#1 2017-10-03 21:53
Q4OS Scorpion 2.3.6, Final beta
Q4OS Scorpion 2.3.6, Final beta has been released, the new stable version will be available in a few days, see https://www.q4os.org/blog.html#news171004
#2 2017-10-03 22:12
Re: Q4OS Scorpion 2.3.6, Final beta
Looking forward to the new stable version.
#3 2017-10-03 23:44
I just had what I thought was the update package set (most tde packages) for updating to 2.3.6 but get_q4os_version.sh is reporting 2.3.5-n1, is this an oversight or normal and would I need to perform a fresh install to get the full upgrade?
#4 2017-10-04 00:10
Im assuming there will be installation cds for the new stable version, not just the live cd?
#5 2017-10-04 07:23
You don't need to perform a fresh install, the 'q4os-desktop' 2.3.6 package is already up in repositories. Anyway, we will recommend to perform the clean Q4OS installation, as the final stable will be released, although it is not necessary.
#6 2017-10-04 07:30
Initially, there will be live media only available, later we want to release following:
x64/64bit arch:
- live-cd
- installation-cd
- Windows installer
- setup script for Debian based Linux
i386/32bit arch:
- installation-cd
arm64/64bit arch:
- dedicated images for Pine64 hardware
armhf/32bit arch:
- dedicated images for Raspberry Pi hardware
#7 2017-10-04 12:20
Great work guys! And just to note I updated another machine and it is reporting the correct version now (2.3.6-n1) I noticed an update to q4os-desktop which I imagine fixed it. smile
#8 2017-10-04 22:27
Thanks for the update. I find the installation cd is much easier for doing mass installs of which Ive done many recently.
