Ok I have installed Scorpion and updated
root@unknownfcaa14c05847:~# inxi -F
System: Host: unknownfcaa14c05847.attlocal.net Kernel: 4.9.0-3-amd64 x86_64 (64 bit)
Desktop: N/A Distro: Debian GNU/Linux 9 (stretch)
Machine: Device: desktop System: Gigabyte product: N/A
Mobo: Gigabyte model: Fxxxxxxxxxx v: x.x
BIOS: American Megatrends v: FA date: 01/08/2015
CPU: Dual core AMD A4-7300 APU with Radeon HD Graphics (-MCP-) cache: 2048 KB
clock speeds: max: 3800 MHz 1: 3100 MHz 2: 2200 MHz
Graphics: Card: NVIDIA GK208 [GeForce GT 720]
Display Server: X.org 1.19.2 driver: nvidia
tty size: 80x25 Advanced Data: N/A for root
Audio: Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
driver: snd_hda_intel
Card-2 NVIDIA GK208 HDMI/DP Audio Controller driver: snd_hda_intel
Card-3 DigiTech driver: USB Audio
Sound: Advanced Linux Sound Architecture v: k4.9.0-3-amd64
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169
IF: enp2s0 state: up speed: 100 Mbps duplex: full
mac: fc:aa:14:c0:58:47
Drives: HDD Total Size: 480.1GB (2.9% used)
ID-1: /dev/sda model: KINGSTON_SV300S3 size: 480.1GB
Partition: ID-1: / size: 25G used: 5.2G (23%) fs: ext4 dev: /dev/sda8
ID-2: /home size: 98G used: 113M (1%) fs: ext4 dev: /dev/sda9
ID-3: swap-1 size: 8.59GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 0.0C mobo: N/A gpu: 30C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 182 Uptime: 4 min Memory: 529.3/7931.1MB
I am setting up OpenVpn that i usually use. I have installed as follows
1. network-manager
2. network-manager-gnome
3. network-manager-openvpn
also i have installed all of openvpn
1. OpenVPN
2. OpenVPN LDAP authentication module
3. OpenVPN RADIUS authentication module
4. openvpn-auth-radius
5. OpenVPN with systemd-resolved
easy rsa is in there too
Yet when i try to set up thru network manager I get this error message as follows
Could not create connection
Could not load editor vpn plugins for "org.freedesktop-NetworkManager.openvpn" (missing plugin file "/urs/lib/x86_64-linux-gnu/NetworkManager/libnm-vpn-plugin-openvpn-editor.so")
I can run my VPN thru a terminal command but is this supposed to be throwing the error? It does set up thru the network manager in kde5 so why not on this one?
You need to install 'network-manager-openvpn-gnome' package, from package manager or terminal:
$ sudo apt-get install network-manager-openvpn-gnome
root@unknownfcaa14c05847:~# inxi -F System: Host: unknownfcaa14c05847.attlocal.net Kernel: 4.9.0-3-amd64 x86_64 (64 bit) Desktop: N/A Distro: Debian GNU/Linux 9 (stretch) Machine: Device: desktop System: Gigabyte product: N/A Mobo: Gigabyte model: Fxxxxxxxxxx v: x.x BIOS: American Megatrends v: FA date: 01/08/2015 CPU: Dual core AMD A4-7300 APU with Radeon HD Graphics (-MCP-) cache: 2048 KB clock speeds: max: 3800 MHz 1: 3100 MHz 2: 2200 MHz Graphics: Card: NVIDIA GK208 [GeForce GT 720] Display Server: X.org 1.19.2 driver: nvidia tty size: 80x25 Advanced Data: N/A for root Audio: Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller driver: snd_hda_intel Card-2 NVIDIA GK208 HDMI/DP Audio Controller driver: snd_hda_intel Card-3 DigiTech driver: USB Audio Sound: Advanced Linux Sound Architecture v: k4.9.0-3-amd64 Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169 IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: fc:aa:14:c0:58:47 Drives: HDD Total Size: 480.1GB (2.9% used) ID-1: /dev/sda model: KINGSTON_SV300S3 size: 480.1GB Partition: ID-1: / size: 25G used: 5.2G (23%) fs: ext4 dev: /dev/sda8 ID-2: /home size: 98G used: 113M (1%) fs: ext4 dev: /dev/sda9 ID-3: swap-1 size: 8.59GB used: 0.00GB (0%) fs: swap dev: /dev/sda2 Sensors: System Temperatures: cpu: 0.0C mobo: N/A gpu: 30C Fan Speeds (in rpm): cpu: N/A Info: Processes: 182 Uptime: 4 min Memory: 529.3/7931.1MB Client: Shell (bash) inxi: 2.3.5 root@unknownfcaa14c05847:~#
1. network-manager 2. network-manager-gnome 3. network-manager-openvpn
1. OpenVPN 2. OpenVPN LDAP authentication module 3. OpenVPN RADIUS authentication module 4. openvpn-auth-radius 5. OpenVPN with systemd-resolved
Could not create connection Could not load editor vpn plugins for "org.freedesktop-NetworkManager.openvpn" (missing plugin file "/urs/lib/x86_64-linux-gnu/NetworkManager/libnm-vpn-plugin-openvpn-editor.so")
Wow, U ever feel like a nut? I thought I had that installed but what i had installed was
network-manager gnome
but I failed to install 5 down. Tks. This may be a OS to work with for a while.
