#1 2017-09-22 16:45
likevinyl
Language pack setup troubles
Hello friends! I'm experiencing difficulties to install language pack in Spanish. the progress bar is set at 10% and never ends. is it a problem with repositories?
Orion version i686-pae
thnx + beers from Argentina! \m/
#2 2017-09-22 17:07
Re: Language pack setup troubles
No, there should be no problem with repositories. We will try to assist you to resolve the issue, please try to switch to console terminal ctrl-alt-f1, login and run command:
$ reportq4
and attach generated file here, or send it via e-mail support@q4os.org to analyze.
#3 2017-09-22 17:57
likevinyl
$ reportq4
Thanks for your help! After 30 minutes, the installation is complete. (50mbps) downloads at 54kbps or less.
Here i send the report, thanks again!
#4 2017-09-28 00:01
There is no problem in log files, but the download speed is very weak. As the Spanish language pack size is about 32MB, you would need to wait about 1.5 hour at 50kbps download speed to complete the download.
#5 2017-11-01 21:52
best
Hi
I have same problem. After installation i tried change language, then an error "Installation has not completed, package system is busy. You can easily install language pack later, using a desktop icon."
Thanks a lot.
