#1 2017-09-07 13:27
Jerome
Program won't launch from desktop icon
I have compiled some software from source (configure, make, make install) but when I tried to run it I got an error about not being able to find a shared object even though I had added the location to my PATH (the shared object is in /usr/local/lib). After some googling I discovered that for library files you need to use the variable LD_LIBRARY_PATH, not PATH, for shared objects. So I added this line to my .bashrc:
export LD_LIBRARY_PATH=/usr/local/lib
The program now runs ok but only from a terminal, not from a desktop icon. I see there is an option to enable launch feedback but where can I see it? Any suggestions? Thanks.
#2 2017-09-07 23:04
Re: Program won't launch from desktop icon
If your program works from the command line, I can't see any reason why it shouldn't work from a desktop link.
How do you have the link set-up?
Sometimes you will need to give the "work path" to the link so it knows where in the system it should be working, I had this happen once and simply entered my home directory as the work path and it then worked without issue.
There is also an option to run your link in a terminal under the advanced options, but it would really depend upon your application as to whether this is relevant.
#3 2017-09-08 09:28
Jerome
Thanks for replying. No I can't see any reason why it shouldn't run from the desktop link if it works from the command line either. I set up the link from the start menu, using right-click and 'add item to desktop'. Anyway I solved the problem by recompiling the software and installing into my home folder rather than /usr/local.
#4 2017-09-08 22:37
You probably need to edit the application shortcut, the '.desktop' file, and modify 'Exec=' line the following way:
Exec=LD_LIBRARY_PATH=/usr/local/lib <original_command>
You can also specify to launch a program in terminal by adding line:
Terminal=true
