#1 2017-09-01 12:58
liquidsnake
How to remove other desktop environments?
I installed the XFCE and LXDE desktop environments just to test them out and see how they look. Now I want to remove them but I guess I'm not entering the right command in the Terminal. What's the correct command to remove these two completely? Thanks in advance!
#2 2017-09-02 11:07
Re: How to remove other desktop environments?
First, you need to list installed packages in terminal:
$ sh /usr/share/apps/q4os_system/bin/altde_util.sh --list-packages XFCE
$ sh /usr/share/apps/q4os_system/bin/altde_util.sh --list-packages LXDE
Remove listed packages this way:
$ sudo apt-get autoremove <listed_packages>
#3 2017-09-02 23:03
Just a word of warning, this will list q4os-network-manager, gksu, desktop-base and probably a few others that you might not want to remove...
#4 2017-09-03 00:07
liquidsnake
Ok thank you so much!
#5 2017-09-03 00:07
liquidsnake
Thanks for the heads up!
#6 2017-09-03 02:24
Ive been using XFCE with Q4OS and installed it with Synaptic no issues and decided to remove it with Synaptic and also had no issues.
Same with a few other distros Im using.
#7 2017-09-21 18:13
vmonev
Why not fresh install? It would help too, I suppose.
