Why is it pointer blocks when I try to use a command line when is only on the terminal tray that blocks since the pointer doesn't block out of the terminal tray with the others applications? And where do I go fetch the password the terminal tray ask for to follow with the command process?
Please specify, which way do you access the terminal ?
