#1 2017-06-30 11:21
amarga49
Kazam
Downloaded and installed but it's not working.
#2 2017-06-30 11:40
Re: Kazam
Please specify in more detail for us to be able to provide a support for you.
EDIT: Please follow Dai_trying advice below, thanks Dai_trying.
#3 2017-06-30 11:40
Re: Kazam
I just downloaded it and it recorded screen and sound without any issue, I am using Scorpion though and don't have access to an Orion install at the moment so if anyone else could try and let us know if it makes any difference.
@amarga49: Can you let us know what system you are using (Pc/Laptop/Pi/Other) and also what version of q4os (run get_q4os_version.sh from terminal) so we can try to reproduce the error.
#4 2017-06-30 14:53
amarga49
Re: Kazam
Sorry for not specifying my issue, I'm using PC dual core processor, 4gigs of RAM, nvidia graphic card gt9500, q4os1.8.7orion just installed 2days ago fully updated. I'm using kazam in my other distribution in another partition with this system without a problem. Downloaded it (kazam) from the terminal and tried it also from synaptic it installed properly but when I tried to open it, it seems it's trying to start then it just goes off, tried it several times it just don't start. anyway,Thanks for the fast reply.
#5 2017-06-30 15:51
Re: Kazam
You should only need to install 'pulseaudio' package using Synaptic or terminal command:
$ sudo apt-get install pulseaudio
#6 2017-06-30 17:26
amarga49
Re: Kazam
Thank you very much Q4OS Team it's up and running. again thanks and cheers!!!
