#1 2017-06-12 07:03
cpcnw
[FIXED] Best way to handle .deb files?
I want to install this
https://anydesk.com/download
whats the best way to handle .deb under q4os?
Thanks
#2 2017-06-12 07:12
cpcnw
Re: [FIXED] Best way to handle .deb files?
I manually extracted to a temp folder
$ dpkg-deb -x anydesk_2.9.1-1_amd64.deb /home/temp
The main executable complains
./anydesk: error while loading shared libraries: libgtkglext-x11-1.0.so.0: cannot open shared object file: No such file or directory
there are no libs included in the .deb
reminds of 'dll hell' on that other os lol!
#3 2017-06-12 07:13
Assuming 64 bit version downloaded
Option 1:-
Open terminal in download folder
sudo dpkg -i anydesk_2.9.1-1_amd64.deb
Option 2:-
Use either synaptic or command line to install gdebi (sudo apt-get install gdebi)
Then right click on anydesk_2.9.1-1_amd64.deb
Open with>gdebi
gdebi will look for dependencies and resolve them as part of the install.
This does of course come with a health warning - any application installed from outside the normal repositories is at your own risk etc etc etc
#4 2017-06-12 07:13
cpcnw
Thanks
gdebi worked perfectly and fetched deps
AnyDesk works fine too smile
Would still be using TV11 but its nagging hell out of me [used on one PC only]
