#1 2017-06-05 23:10
Adding boot parameters to grub
To add a boot time parameter to grub you can select the Q4OS boot entry (usually already selected) and then press e which will put you in edit mode, you will then be presented with a screen like the one below
To add a boot parameter simply locate the line that begins linux    /boot/vmlinuz... and add at the end of that line the parameter ie "acpi=off" like in the screenshot below.
and then press Ctrl-x or F10 to boot the system.
This will add the boot parameter for this session only.
To make this change permanent:
From a terminal (konsole) run:
sudo nano /etc/default/grub
and enter your password.
Find the line starting with GRUB_CMDLINE_LINUX_DEFAULT and append acpi=off (for this example) to its end. For example:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi=off"
Save the file and close the editor (press Ctrl-x then type y followed by pressing enter).
Finally, start a terminal and run:
sudo update-grub
to update GRUB's configuration file.
#2 2017-06-05 23:15
Re: Adding boot parameters to grub
Thanks for posting this Dai!
Q4OS Aquarius 5.x KDE   Dell Latitude 5450/7450 I5 2.3ghz, 16gb,256gb ssd
#3 2017-06-05 23:18
You're welcome. smile
#4 2017-06-05 23:20
Its one of the problems I have as I live in the States and Im still at work when most of you are calling it a night.
#5 2017-06-06 00:27
hg
Thanks Dai. That worked . It booted fine to desktop. I guess I have add that acpi=off to Grub.cnf (?)  now using an editor. Tomorrow I will install all the updates (from a WIFI, RJ45 doesnot work :-) )
BTW Crosscourt I am a Canuck on CDT.
Thank you gentlemen for your help
#6 2017-06-06 00:40
Someone from North America!
Glad that worked as its a common problem with older laptops and bios.
RJ45 doesnt work, thats curious as Ive never had that issue with that system.
Trying to remember but I think it uses a Brioadcom Lan driver so we may need to install a Broadcom driver but typically Ive only seen them for wireless chipsets.
Glad youve got WIFI.
#7 2017-06-06 01:32
I believe youre using the Broadcom BCM4401 ethernet controller so might find this article from 2010 interesting,
http://askubuntu.com/questions/14970/br … -tx-issues
It could also be that there isnt a driver available as I dont see the b44 driver listed in Synaptic.
So far Q4OS has been fine with all my Dell laptops that use Broadcom chipsets but many use Intel chipsets for ethernet.
#8 2017-06-06 02:19
Heres the tech manual for your laptop,  http://tim.id.au  click on laptops, then in the right column click on Acer, slide down the page and under Travelmate click on the 4500 pdf.
#9 2017-06-06 08:22
@hg I have updated the OP to show how to make changes permanent.
#10 2017-06-06 16:28
Thanks Dai  smile
#11 2017-06-06 20:04
You're welcome smile
