#1 2017-06-01 16:22
JimW
Oracle
Is oracle or another vm available for Scorpion? Or have I been missing it in synaptic?
#2 2017-06-01 18:22
Re: Oracle
You will need to add the virtualbox repo (assuming you are still using Scorpion) which can be done with
sudo qrepoadd virtualbox
or you can use
sudo qrepoadd --gui
and select virtualbox from the dropdown.
Then update apt and you will have the choice of either virtualbox-5.0 or virtualbox-5.1
#3 2017-06-01 19:55
JimW
Re: Oracle
Thanks Dai - new tricks all the time! Now if this ol dog can remember them! smile
#4 2017-06-01 21:51
Re: Oracle
That's the good thing about posting a question, you don't need to remember, you just need to search your own posts, win win eh. smile
#5 2017-06-01 22:13
Re: Oracle
LOL!! We are happy to answer any questions that we have already answered as many times as necessary, wink
