#1 2017-05-21 20:29
bne1652
whats the password when typed in "su"
I just want to install a .deb-package vie 'apt install ... '. But when I switched to 'root' with 'su' I dont hav a valid Password. What shall I do?
regards from GER
#2 2017-05-21 21:14
Re: whats the password when typed in "su"
You need to type in terminal:
$ sudo su
to get root console.
#3 2017-05-21 21:25
bne1652
Okay, thx. I found out that there is just another way (sudo apt ....), wich works.
#4 2017-05-22 00:43
Welcome to the site, bne1652!
