#1 2017-05-03 04:13
JimW
Firefox/Thunderbird fight!!
Ok, maybe not a fight, just a disagreement over the exact same thing as far as I can see!
I have a shortcut on my desktop for FireFox-esr which opens /usr/bin/firefox-esr
I have set Thundrbird to use /usr/bin/firefox-esr for opening web links
However, when I click a link in Thunderbird, it opens FireFox-esr and pops up the box that FireFox is not my default browser and asks if I want to set it as default. If I answer yes it continues. Checking the about shows it is FireFox ESR 52.1.0 - ok, great, what I wanted!
Later, if I click my shortcut on the desktop I get a repeat of the popup asking if I want to set FireFox as my default browser! Again I answer Yes. And again checking the About shows it as FireFox-ESR-52.1.0
???Same thing! But Thunderbird does not recognize that it was set by the shortcut and the shortcut does not recognize that it was set by Thunderbird!
This repeats again if I go back to Thunderbird and click a link.
Doesn't hurt anything, that I can see. Just a minor irritation that I have to click either yes or no between the two situations. smile
Oh - if I click NO it opens okay and does not disturb the other, but I have to do it each time for that situation (in Thunderbird or from desktop).
#2 2017-05-03 09:13
Re: Firefox/Thunderbird fight!!
I have had a similar issue (kinda) that user set preference were not observed and I think it stems from having so many different ways to set the default browser, if two programs use different methods for checking the default then there is going to be a problem somewhere...
I would start by looking at Settings -> Control Centre -> TDE Components -> Default Applications -> Web Browser and ensure in the following browser is checked and set to firefox-esr.
Second thing I would check is that
sudo update-alternatives --config x-www-browser
is set to firefox-esr.
If either of those are set for something else that could be the problem.
HTH
#3 2017-05-03 13:23
JimW
Would this be a problem?
There are 5 choices for the alternative x-www-browser (providing /usr/bin/x-www-browser).
  Selection    Path                           Priority   Status
*0            /usr/bin/google-chrome-stable   200       auto mode
  1            /opt/trinity/bin/konqueror      100       manual mode
  2            /usr/bin/firefox                70        manual mode
  3            /usr/bin/firefox-esr            70        manual mode
  4            /usr/bin/google-chrome-stable   200       manual mode
  5            /usr/bin/iceweasel              70        manual mode
Press enter to keep the current choice "["*"]", or type selection number:
since the current choice is 0 I will try changing it to 3 and see if that helps.
Thanks Dai!
#4 2017-05-03 14:10
JimW
Ok, that didn't help.
However, if I have FireFox open and then open Thunderbird and click on a link in it, then it will use the open FireFox. I'll just use that method, since I usually go to both email and web during the same period and having both open is no problem.
#5 2017-05-03 14:52
Strange that... I'm having issues trying to use a gmail account, I was trying to set it up to test what browser it tries to use, I'll sort it out and post back if I find anything. smile
#6 2017-05-03 20:06
Ok this is more than a little strange, I couldnot get thunderbird (Debian v45.8) to verify my gmail account so posted a question on mozilla site. The answer I got was to upgrade to a newer version as this problem was fixed in 52.1, I decided to download the latest version from mozilla (52.1) and unpacked the tar.bz2 file to my home directory and created a link on my desktop to the thunderbird file, runs without issue. I decided to do the same with firefox (Debian v45.9 : Mozilla v53.0) and followed the same procedure.
Just to note I did uninstall the firefox and thunderbird packages before doing this. I now cannot access thunderbird or firefox by directly calling them from the command line which is no surprise as they are no longer in my $PATH. But when I click a link in thunderbird it opens firefox to the page in the link!!! How does this happen? The only thing I can think of is that thunderbird must search for firefox in my home directory...
The bottom line is thunderbird is using firefox even though it is not in any $PATH variable. Like I said I am using the latest versions from the mozilla site and did not have to install anything else, simply unpacked to home folder and run the firefox/thunderbird command (from their own folders) and without any installation they are working as they should (so far anyway).
I don't know if this information will be of any use to helping you but thought I'd let you know anyway. smile
#7 2017-05-04 02:19
JimW
Most software when they go to making changes that may mess with the users minds let the user know in advance! Guess the rules are changing!
Thanks Dia
