#1 2017-04-22 13:53
geekapalooza
Thunderbird Installer Fails with Dependencies
This behavior seems to be recent because I installed Q4OS earlier this week and completed the full desktop option of the profiler, but I just did a re-install (several of them now, at this point) and the installer for Thunderbird seems to be failing due to iceowl/icedove dependencies.  I installed both the iceowl-extension and icedove via the Synaptic Package Manager and tried the Thunderbird installer again, but I keep receiving the same error:
Simulation not successful, sorry, I cannot install now.
Cleaning and canceling ...
And here's more detail from the Thunderbird installer:
Reading package lists... 100%
Reading package lists... Done
Building dependency tree
Reading state information... 0%
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
thunderbird-q4 : Depends: iceowl-extension
Depends: icedove
E: Unable to correct problems, you have held broken packages.
Testing installation ... Done
I would greatly appreciate any help or insight, please - thank you!
#2 2017-04-22 14:23
Re: Thunderbird Installer Fails with Dependencies
This situation can often arise when the apt-database is old, you can try
sudo apt-get update
before trying again to see if it helps.
EDIT: I just tested and the debian package installer works fine (sudo apt-get install thunderbird) , but the Q4OS Software Centre installation fails, in my case the error was
icedove-l10n-en-gb : Depends: thunderbird-l10n-en-gb but it is not going to be installed
iceowl-l10n-en-gb : Depends: lightning-l10n-en-gb but it is not going to be installed
Depends: icedove
Tested in Q4OS Orion 1.8.3-n2 VM
#3 2017-04-22 16:26
geekapalooza wrote:
... Thunderbird seems to be failing due to iceowl/icedove dependencies. ...
Yes, we can confirm a bug in Q4OS, it will be fixed as soon as possible, hopefully in several hours.
#4 2017-04-22 17:33
Fixed, you can proceed Thunderbird installation.
#5 2017-04-22 17:39
geekapalooza
Confirmed! Wow! I'm truly impressed by the amazingly fast response to this issue. THANK YOU!!
