#1 2015-12-30 09:22
bobby
Using Local Repository After Booting Q4OS LiveCD
I am posting in General Section as I am no Developer smile
That being said thought, I am trying to develop smile a post Local Package Repository using a USB Thumb Drive with Q4OS LiveCD session.
I was thinking about remastering the Q4OS Live CD but, that's overkill as all that I need for Q4OS to be prefect is for Apache Webserver to be Installed in the Live CD environment.
My Schema is:
--> create a new myq4osrepo.list file in:  /etc/apt/sources.list.d/
--> insert in new myq4osrepo.list file:
      # My Local Repository *.list file
      deb file:///media/adminq/MYQ4OS/Repository
      #MYQ4OS is volume name of USB Thumb Drive and proper path - works in terminal
--> Create a directory on USB Thumb Drive /media/adminq/MYQ4OS/Repository
--> Copy Apache2.xx.xxxx.deb and all dependencies to /media/adminq/MYQ4OS/Repository/
--> cd '/media/adminq/MYQ4OS/'
--> root@debian:/media/adminq/MYQ4OS# dpkg-scanpackages Repository | gzip > Repository/Packages.gz
FAILED Result: bash: dpkg-scanpackages: command not found
I have tried as root; with and without sudo;  installed dpkg-dev package;
Also used:    dpkg-scanpackages Repository/null | gzip -9c > Repository/Packages.gz
STILL FAILS:
Any Ideas ? of how to get dpkg-scanpackages work in Q4OS Live CD ?  "OR"
Plan B: Create Bash Executable .sh script  + Build Q4OS Installer Executable .esh  to get Apache Installed from Local Repo
OR
Plan C: PUNT smile
No Longer Using Q4OS
#2 2015-12-31 10:42
Re: Using Local Repository After Booting Q4OS LiveCD
Moved from 'General discussion'
You have to install 'dpkg-dev' package:
$ sudo apt-get install dpkg-dev
#3 2015-12-31 17:49
bobby
Yes, afteri installing dpkg-dev package and it works now, THANKS !
Also, installed gdebi for testing purposes as well.
#4 2015-12-31 20:16
bobby
Is there an easy way to download a .deb package and required dependencies. In U's Software Center I have read you can right click a deb and it will create a download script for local installs.
a task that can not be done using dpkg command line.
Any suggestions ?
#5 2016-01-02 01:04
#6 2016-01-02 02:14
bobby
Q4os Team, Thank you Very Much ! - Happy New Year
