#1 2017-03-16 15:03
michaelk
New installation - /etc/apt/sources.list is empty
Hi,
I just installed Q4OS, runs smooth. Synaptic works - but I checked /etc/apt and found there is no content in the sources.list. Is this „normal“, did I make any mistake?
#2 2017-03-16 18:21
Re: New installation - /etc/apt/sources.list is empty
Q4OS uses the files in /etc/apt/sources.list.d/ for this.
#3 2017-03-16 18:27
michaelk
Thanks a lot! Good to know! If one is only a bit experienced with Debian it is kind of surprising.
# Q4OS essential repository
# **** !!! NEVER touch this CRITICAL system file **** !!!
And nice that this is written within the file! ;-)
#4 2017-03-17 01:41
You can still use the sources.list file if you have to add a repository that is not within Q4OS lists, and if you really wanted you could add the entries from the sources.list.d directory into the sources.list file manually and remove them from sources.list.d, although it would definitely NOT be a recommended way to do things, just another option.
#5 2017-03-17 10:42
aldrik
Hello,
so how can I have this new on my system ?
https://www.jurisic.org/index.php?post/ … e-in-3-min
with the depot deb http://apt.jurisic.org/debian/ jessie main contrib non-free
thank you for help
aldrik
#6 2017-03-17 10:52
you can just follow the instructions on the page you linked to. smile It adds a file to the /etc/apt/sources.list.d/ folder which in turn populates the apt database, from there you can install it in the usual manner.
#7 2017-03-17 10:57
aldrik
I try this, but don't work...
aldrik@q4os-desktop:~$ echo 'deb http://apt.jurisic.org/debian/ jessie main contrib non-free' >> /etc/apt/sources.list.d/nextcloud.list
bash: /etc/apt/sources.list.d/nextcloud.list: Permission non accordée
aldrik@q4os-desktop:~$ sudo echo 'deb http://apt.jurisic.org/debian/ jessie main contrib non-free' >> /etc/apt/sources.list.d/nextcloud.list
I'm a noob smile
#8 2017-03-17 11:04
Easiest way is to become root first with
sudo su
You will have to enter your password here.
Then run your command
now exit from root
exit
And simply continue with update and then installation. smile
#9 2017-03-17 11:21
aldrik
All is working thank you very much...
#10 2017-03-17 13:21
You are welcome smile
