#1 2017-01-22 07:15
Bourbon shortcuts right side modifications...
So, not sure how to do this.  I like the shortcuts on the right side of the bourbon menu, but not all of them.  right now I've turned off the default ones, and have my custom ones.  I have the q4os software center and find files still like the defaults, and I've added konsole and dolphin.  I'd like to add a control center like the defaults have (basically, I like the defaults but want konsole & dolphin instead of browser which is in my favorites).  Any way to do this?
#2 2017-01-23 09:58
Re: Bourbon shortcuts right side modifications...
Did you follow this document ?
https://q4os.org/dqa011.html#desktop.4
#3 2017-01-23 23:57
Yes.  That doesn't say how to create a .desktop file that'll open Konqueror in control centre mode.
#4 2017-01-24 01:50
You can just right click on the Control Centre entry from the standard menu and select Add Item To Desktop then you will have the file /home/user/Desktop/q4os-controlpanel.desktop which you can either use or just copy the Exec line from it to use as you wish. smile
#5 2017-01-24 15:16
That worked, just had to add the line to the .desktop file for Hidden=True (I hate anything showing on my desktop) and it worked great!  Thanks!!
#6 2017-01-24 15:18
You're welcome smile
