#1 2017-01-02 08:53
zebedeeboss
Kernel upgrade to 4.7 [SOLVED]
Hi
apologies if this is shown somewhere else - I cannot find it.
How do I upgrade the kernel to 4.7 for example.
Many Thanks in advance
Regards Zeb...
edit:  Will I have to un-install Nvidia drivers first as well ?
Answer: No just use the command detailed below
Be Kind Whenever Possible...   It is Always Possible - Dalai Lama   Linux User #565092   x64 Desktop - Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz - 32Gb RAM - NVIDIA GTX 1060 6Gb - 43"  4k  3840x2160   x64 Laptop - Intel(R) Dual Core i5-4200U - 8Gb RAM - Intel Integrated Graphics - 15.6"  HD 1920x1080
#2 2017-01-02 09:18
MC
Re: Kernel upgrade to 4.7 [SOLVED]
Hi Zeb. For installing kernels on Q4OS, have a look here first: http://www.q4os.org/dqa011.html#system.5
Q4OS running Xfce
#3 2017-01-02 09:21
zebedeeboss
Many thanks for the link.  I need it for my nvme ssd card which is currently not seen by Q4OS.
Fingers crossed it works for me  smile
Regards Zeb...
#4 2017-01-02 09:36
zebedeeboss
Hi
OK that worked very well. Thank you and I am now on kernel 4.8.11-1.   However gparted it is still not seeing my nvme ssd.
I will now search the forums and the website for further info
Regards Zeb...
edit:  Interesting:-  using blkid does see nvme0n1 drive
