OK, long story short - I created a dual-boot yesterday, crunchbang wheezy (32bit) and Q4 orion (32bit), and there is a shared storage partition (ntfs). Also, I installed disk-mamager and set it to mount the partition at boot.
Deleting a file from the storage partition in #! sends the file to the trash, but in Q4 I get this message:
Some files cannot be moved to trash can because the underlying file systems don't support this operation.
Do you want to delete them instead?
I know wheezy and jessie are two different systems, mostly due to systemd, but I'm not sure how to change this action in Q4 to send the deleted files to trash.
- Thanks in advance for any help.
(Here's my Q4 fstab)
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
#Entry for /dev/sda2 :
UUID=386ed212-ad0f-45a0-93c3-a48700c74500 / ext4 errors=remount-ro 0 1
#Entry for /dev/sda4 :
UUID=633706CC7A983F88 /media/mc/Storage ntfs defaults,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177,uhelper=udisks2 0 0
/dev/sr0 /media/cdrom0 udf,iso9660 user,noauto 0 0
Q4OS running Xfce
Deleting a file from the storage partition in #! sends the file to the trash, but in Q4 I get this message...
Do you use PCManFM file manager ? If so, information in this thread could solve the issue https://bbs.archlinux.org/viewtopic.php?id=207042 , please see the last post.
I do use PCManFM. Solution #1 fixed the problem.
Thank You!
Q4OS running Xfce
