#26 2016-11-05 08:49
aldrik
Re: A simple small update notifier
Hello
Really good ! How to autostart it ?
have a good day
#27 2016-11-05 10:32
Thank you @aldrik, it will auto-start when you boot the machine, you do not need to do anything smile
#28 2016-11-05 14:27
aldrik
Thank your for all !
#29 2016-11-05 23:27
Small changes to the updater as I found a couple of minor bugs, new version 0.0.1-11 fixes them.
#30 2016-11-09 21:52
I have added the option to disable unattended upgrades to the context menu (right click), it will only appear if it is configured on.
#31 2016-12-14 15:45
Reporting an issue, we have tried to run updater with defined delay from command line:
$ apt-updater -d 1
got python error:
Traceback (most recent call last):
  File "/usr/share/dai-apt-updater/updater.py", line 397, in <module>
    main(sys.argv[1:])
  File "/usr/share/dai-apt-updater/updater.py", line 391, in main
    tray_icon = SystemTrayIcon(QtGui.QIcon(":/plain.png"), w)
  File "/usr/share/dai-apt-updater/updater.py", line 169, in __init__
    "Waiting for Delay period\nSceduled for " + (start + timedelta(seconds=delay)).strftime("%H:%M:%S"))
TypeError: unsupported type for timedelta seconds component: str
Fresh Q4OS Orion installation.
#32 2016-12-14 16:45
Thanks guys, I will investigate and post with a fix (hopefully) smile
#33 2016-12-14 17:08
New Version 0.0.1-16 Fixes this issue.
#34 2016-12-14 18:16
We can confirm fixed issue mentioned above, thanks.
#35 2016-12-15 14:43
Just another issue, 0.0.1-16 updater on a fresh Orion system with some pending updates. Ran updater from the command line:
$ apt-updater -d 1 -i 80
Updater correctly reports updates available, click to updater icon to show updates to go -> then click Cancel -> again click to updater systray icon, but no Synaptic window appears anymore. There are a few python errors in terminal too:
In addition, would it be possible to modify code to check, if APT is ready using Q4OS specific command '/usr/bin/check-apt-busy' ? See the line 86 of 'updater.py'. Command 'check-apt-busy' returns '0' if APT is free, otherwise some non zero value. We suggest you to perform simple test for presence of '/usr/bin/check-apt-busy' file exists in the filesystem, and use it if so, otherwise keep the current 'lsof ...' command.
#36 2016-12-15 19:50
I have fixed this new issue in Version 0.0.1-17
@Q4OS Team
  I did originally code the apt-check to use '/usr/bin/check-apt-busy' but changed it to lsof to allow it to work on both q4os and debian. I removed the check-apt-busy as I deemed it to be unnecessary and to avoid the overhead of using two different methods. I can incorporate it again and like you suggest add a check to ensure it is available and use lsof as a fallback, although I can see no benefit from doing so.
#37 2016-12-15 21:33
Yes, please do it so, if possible. We consider the 'check-apt-busy' checker as more reliable. Thank you for fixing and developing.
#38 2016-12-15 22:25
Updated Version 0.0.1.18 now uses Q4OS check-apt-busy script. smile
#39 2016-12-16 08:46
There is probably some mistake, as 0.0.1-18 looks exactly the same as 0.0.1-17.
#40 2016-12-16 09:46
My apologies, I didn't move the new source to the installer folder, new Version 0.0.1-19 will fix this.
#41 2016-12-18 10:15
@Dai_trying
We could suggest you a fix of this issue http://www.q4os.org/forum/viewtopic.php?pid=6110#p6110 , 'apt-get update' could be performed prior to upgrade, if updater detects disrupted backports pinning.
#42 2016-12-18 11:18
Ok, I will work on this later today (a few chores to do first sad ) and post new version when available. smile
#43 2016-12-29 10:06
Apologies for the delay, but now the festivities are coming to an end I had time to finish the fix for this.
New Version 0.0.1-20 should fix this issue
#44 2017-04-15 12:49
samberry
Thank you i will test that.
#45 2017-04-15 15:35
You are welcome samberry, let me know if you find any issues. smile
#46 2017-05-07 19:56
Ill have to give this a try Dai and post back.
#47 2017-05-07 20:15
Thanks CC, I am planning a major overhaul when I have more free time, I am hoping to implement a update chooser so you will be able to select which updates get installed, and also a hold option (like pinning but not) which will be good for when an update breaks something. smile
#48 2017-05-07 20:17
Something to look forward to, smile
#49 2017-05-08 18:36
aldrik
Hello, can I install it on Scorpion ?
#50 2017-05-08 18:37
Yes, I use it all the time Orion and Scorpion smile
