#1 2016-12-04 20:22
Jerome
no icedtea plugin for java 8
I have just upgraded java to version 8 but there is no icedtea plugin for it. When I go to install 'icedtea-plugin' apt-get tries to install the old version of java. I found a bug report about this here :
https://bugs.launchpad.net/ubuntu/+sour … ug/1385842
Any suggestions?
#2 2016-12-05 11:25
Jerome
Re: no icedtea plugin for java 8
Package icedtea-8-plugin is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'icedtea-8-plugin' has no installation candidate
#3 2016-12-05 11:37
Unfortunately, 'icedtea-8-plugin' package is not available from Debian nor Debian-backports repositories at the moment. There is a chance, it will be included in backports sooner or later, as the java-8 is already included. The only suggestion now is to use 'java-7' and 'icedtea-7-plugin' from regular Debian repositories.
#4 2016-12-05 17:01
Jerome
Ok, thanks. I guess I can live without it for a while.
#5 2016-12-05 18:59
Yeah, this bug's been around a while.  There are some 3rd parties that have made the package available to install if you trust them (I don't), but otherwise you're stuck with Java7 plugin.
