#1 2016-12-03 15:44
MC
[Solved] How do I get out of "fail-safe"?
...so, I was at the log-in screen, switching session type and clicked on "fail-safe". Now all I have is a terminal.
How do I get back to the TDE login gui?
Thanks for any help.
(I'm on my #! netbook at the moment.)
Q4OS running Xfce
#2 2016-12-03 15:59
Re: [Solved] How do I get out of "fail-safe"?
Type in terminal:
$ sudo reboot
or, if you have autologin enabled, type in terminal:
$ sudo ctrl-autologin --disable
$ sudo reboot
#3 2016-12-03 16:30
MC
$ sudo reboot
Thank You! smile
Q4OS running Xfce
