#1 2016-11-30 19:59
ghostdawg
Need New Wifi Router
I guess my current Netgear router is dying. I can't seem to keep any connections when the router is plugged into my cable modem. No wifi devices or the PC will have a connection, it looses it after around 30 min. or so. The modem is working fine when I plug it directly into my PC. I've had the router for about 5 or so years.  smile
Any recommendations for a nice new one? Nothing expensive, $50 or less.
Thnx.
Dell Optiplex 760 - Quad Core | 4gb | 250gb | Mageia 5, Salix 14.2, Q4OS
Lenovo Thinkpad T420 | 4gb | 120gb | Mageia 5, Debian Testing
#2 2016-12-01 04:16
Re: Need New Wifi Router
I like the Linksys EA6400/6500.  While they don't have all the abilities of some of those with external antennas, and they might not have QUITE as strong a signal, I really like the clean look, and they work well.  I prefer the EA65/6400 to the 63/6200 due to having 3 antennas on the 5 GHz channel as compared to only 2 with the lesser routers (the 6500 also has 3 on the 2.4 GHz band compared to 2 on the 6400).
#3 2016-12-01 09:41
milink
Before buying new router, try replace the power supply. It is usually the source of the problem...
#4 2016-12-01 15:37
Strongly recommend you take a look at some of the articles on www.theregister.co.uk about router vulnerabilities before making any decisions.
#5 2016-12-01 17:07
ghostdawg
Thanks guys. I'll look into all the suggestions.
#6 2016-12-08 15:35
ghostdawg
I ended up getting a Belkin N300 router. So far it has been doing the job for me.
Thanks to all.
