#1 2016-11-23 07:58
TeXnik
Audio output
I am using 3 monitors, the third is a TV screen connected via HDMI to the computer.
With other distributions (Mint, Debian etc.) I also use the TV for audio output. Very easy to select this screen in Mint.
Q4OS does not offer such an easy selection like Mint, or perhaps I was not able to detect this function. Right now I dfo not have any audio output available.
#2 2016-11-23 09:02
Re: Audio output
TeXnik wrote:
Right now I do not have any audio output available.
First, try to follow these instructions to get audio working http://www.q4os.org/dqa011.html#install.3 . If you will need further assistance, post your findings here.
TeXnik wrote:
... I also use the TV for audio output ...
You can select audio output this way: Click to the 'kmix' icon in the system tray -> Run 'Mixer' -> In the top right corner of Mixer window select a sound card -> update mixer levels, focus primarily on 'Master', 'PCM', 'Front' and 'LFE' parameters.
If you have pulseaudio installed, run 'pavucontrol' config tool from the start menu to adjust audio devices.
#3 2016-11-23 16:52
TeXnik
Re: Audio output
It seems that only HDA Intel PCH is working. I can select HDA Nvidia but everthing is blank, only IEC958 is to seen. 4 switches in gray, when selected  they turn to yellow.
As I do not use the internal audio and graphic, it seemes to be a problem with the driver. I could not install the latesdt NVIDIA driver because I was not able to remove the current one.
