#1 2016-11-22 09:31
judydudi
problem with upgrade from Q4OS Repository
Hi,
upgrade with debian repositories runs fine but my system could not upgrade from q4os repositories.
update manager and synaptic and apt-get upgrade brings error message like these:
E: http://q4os.org/q4repo/ q4os-1-0-cn/main q4os-base all 1.9.4-a1 is not (yet) available (404 Not Found [IP: 2a02:4a8:ac24:108::96:231 80])
W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Repository wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: http://q4os.org q4os-1-0-cn InRelease: Die folgenden Signaturen konnten nicht Überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 6ABA85D1E2E6A0B3
any idea? could it be do to with IPv6 ? But other repositorys works fine to me...
#2 2016-11-22 10:26
Re: problem with upgrade from Q4OS Repository
I just ran sudo apt-get update and everything got pulled in without issue (from UK if it makes a difference)
#3 2016-11-22 10:32
First quick test is to use terminal 'ping q40s.org'
That should return an IP4 address - if not then something is wrong!
What I do next may work for you - edit your network connection settings and change the DNS to 8.8.8.8,8.8.4.4 - you need to check the manual setting box.
Log out and back in - your network connection should have refreshed but this will force it to anyway - and yes it can done from the command line.....
apt-get update and see if they all connect OK
#4 2016-11-22 11:29
judydudi
the ping shows a ipv4:
PING q4os.org (81.95.96.231) 56(84) bytes of data.
64 bytes from uvirt25.active24.cz (81.95.96.231): icmp_seq=1 ttl=55 time=39.3 ms
this is my active connection:
[ethernet]
duplex=full
[connection]
id=company
uuid=xy..
type=ethernet
timestamp=1447414263
[ipv6]
method=auto
[ipv4]
method=manual
dns=192.168.1.2;
address1=192.168.1.112/24,192.168.1.2
and here is my resolv.conf
# Generated by NetworkManager
nameserver 192.168.1.2
nameserver fd00::3a10:d5ff:fea9:3dce
should i add or change the DNS in the resolv.conf
still wondering, because debian repositorys works...
#5 2016-11-22 11:54
We are not aware of any Q4OS repositories failure. It may be about some temporary glitch with the IPv6 connectivity at Q4OS webhosting provider. We will check it out as soon as possible and post more info here. Please let us know, as there would be anything new.
#6 2016-11-22 12:08
@judydudi
As the quick result, there should be no issue with Q4OS repository hosting. We will try to assist you to resolve the problem, please run in terminal and post back an output:
$ qrepolist
$ sudo apt-get update
$ sudo apt-get dist-upgrade
$ ping6 q4os.org
$ ping6 2a02:4a8:ac24:108::96:231
EDIT:
Online Ping6 as well as Ping4 works fine for q4os.org, you can verify it by http://www.traceroute6.net/, so we conclude it should be some local issue. You could try to check your local connectivity too.
EDIT:
If anyone else would notice similar issue, please do a report.
EDIT:
@judydudi
Additionally, please run in terminal and post result here:
$ wget http://q4os.org/q4repo/dists/q4os-1-0-cn/main/binary-amd64/Packages
$ wget http://q4os.org/q4repo/pool/main/q/q4os-base/q4os-base_1.4.1-r1_all.deb
$ wget http://q4os.org/q4repo/pool/main/q/q4os-base/q4os-base_1.11.1-a3_all.deb
#7 2016-11-22 13:17
judydudi
switching to ip4 doesn't fix it:
E: http://q4os.org/q4repo/ q4os-1-0-cn/main q4os-base all 1.9.4-a1 is not (yet) available (404  Not Found [IP: 81.95.96.231 80])
wget works fine:
adminq@q4os-desktop:~$ wget http://q4os.org/q4repo/dists/q4os-1-0-c … 4/Packages
--2016-11-22 13:06:57--  http://q4os.org/q4repo/dists/q4os-1-0-c … 4/Packages
Aufl￶sen des Hostnamen ᄏq4os.org (q4os.org)ᆱ... 81.95.96.231, 2a02:4a8:ac24:108::96:231
Verbindungsaufbau zu q4os.org (q4os.org)|81.95.96.231|:80... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 200 OK
L¦nge: 14826 (14K)
In ᄏᄏPackagesᆱᆱ speichern.
Packages            100%[=====================>]  14,48K  --.-KB/s   in 0,04s
2016-11-22 13:06:58 (364 KB/s) - ᄏᄏPackagesᆱᆱ gespeichert [14826/14826]
synaptic packet manager is missing the public Key for Q4OS and give an GPG-Error:
#8 2016-11-22 13:24
Please run 'update && upgrade' and post back the complete output:
$ qrepolist
EDIT:
Alternatively, you could send logs to support@q4os.org
#9 2016-11-22 13:36
judydudi
That's the (in German) output:
adminq@q4os-desktop:~$ qrepolist
deb http://q4os.org/q4repo/ q4os-1-0-cn main
deb http://q4os.org/qtderepo/ jessie main
deb http://ftp.debian.org/debian/ jessie non-free contrib main
deb http://security.debian.org/ jessie/updates contrib non-free main
deb http://ftp.debian.org/debian/ jessie-updates main contrib non-free
deb http://ftp.debian.org/debian/ jessie-backports main contrib non-free
deb http://packages.x2go.org/debian/ jessie main
adminq@q4os-desktop:~$ sudo apt-get update
OK   http://packages.x2go.org jessie InRelease
Ign http://ftp.debian.org jessie InRelease
OK   http://security.debian.org jessie/updates InRelease
OK   http://ftp.debian.org jessie-updates InRelease
OK   http://ftp.debian.org jessie-backports InRelease
OK   http://ftp.debian.org jessie Release.gpg
Holen: 1 http://q4os.org q4os-1-0-cn InRelease [3.931 B]
Fehl http://q4os.org q4os-1-0-cn InRelease
OK   http://security.debian.org jessie/updates/non-free amd64 Packages
Holen: 2 http://ftp.debian.org jessie-updates/main amd64 Packages/DiffIndex [6.424 B]
Holen: 3 http://q4os.org jessie InRelease [3.940 B]
OK   http://packages.x2go.org jessie/main amd64 Packages
OK   http://ftp.debian.org jessie-updates/contrib amd64 Packages
Fehl http://q4os.org jessie InRelease
Holen: 4 http://ftp.debian.org jessie-updates/non-free amd64 Packages/DiffIndex [736 B]
OK   http://ftp.debian.org jessie-updates/contrib Translation-en
Holen: 5 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [2.704 B]
OK   http://security.debian.org jessie/updates/non-free Translation-en
Holen: 6 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
OK   http://security.debian.org jessie/updates/contrib amd64 Packages
OK   http://security.debian.org jessie/updates/main amd64 Packages
Holen: 7 http://ftp.debian.org jessie-backports/main amd64 Packages/DiffIndex [27,8 kB]
OK   http://security.debian.org jessie/updates/contrib Translation-en
OK   http://security.debian.org jessie/updates/main Translation-en
Holen: 8 http://ftp.debian.org jessie-backports/contrib amd64 Packages/DiffIndex [19,8 kB]
Ign http://packages.x2go.org jessie/main Translation-de_DE
Holen: 9 http://ftp.debian.org jessie-backports/non-free amd64 Packages/DiffIndex [14,5 kB]
Holen: 10 http://ftp.debian.org jessie-backports/contrib Translation-en/DiffIndex [6.484 B]
Ign http://packages.x2go.org jessie/main Translation-en
Holen: 11 http://ftp.debian.org jessie-backports/main Translation-en/DiffIndex [27,8 kB]
Holen: 12 http://ftp.debian.org jessie-backports/non-free Translation-en/DiffIndex [10,8 kB]
OK   http://ftp.debian.org jessie/non-free amd64 Packages
OK   http://ftp.debian.org jessie/contrib amd64 Packages
OK   http://ftp.debian.org jessie/main amd64 Packages
OK   http://ftp.debian.org jessie/contrib Translation-en
OK   http://ftp.debian.org jessie/main Translation-de_DE
OK   http://ftp.debian.org jessie/main Translation-en
OK   http://ftp.debian.org jessie/non-free Translation-en
Es wurden 126 kB in 2 s geholt (58,7 kB/s).
Paketlisten werden gelesen... Fertig
W: W¦hrend der ᅵberprfung der Signatur trat ein Fehler auf. Das Repository wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: http://q4os.org q4os-1-0-cn InRelease: Die folgenden Signaturen konnten nicht berprft werden, weil ihr ￶ffentlicher Schlssel nicht verfgbar ist: NO_PUBKEY 6ABA85D1E2E6A0B3
W: W¦hrend der ᅵberprfung der Signatur trat ein Fehler auf. Das Repository wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: http://q4os.org jessie InRelease: Die folgenden Signaturen konnten nicht berprft werden, weil ihr ￶ffentlicher Schlssel nicht verfgbar ist: NO_PUBKEY 6ABA85D1E2E6A0B3
W: Fehlschlag beim Holen von http://q4os.org/q4repo/dists/q4os-1-0-cn/InRelease
W: Fehlschlag beim Holen von http://q4os.org/qtderepo/dists/jessie/InRelease
W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
adminq@q4os-desktop:~$ sudo apt-get dist-upgrade
Abh¦ngigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
Paketaktualisierung (Upgrade) wird berechnet... Fertig
Die folgenden Pakete werden aktualisiert (Upgrade):
  kappfinder-trinity kate-trinity kcontrol-trinity kdesktop-trinity
  kfind-trinity khelpcenter-trinity kicker-trinity klipper-trinity
  kmenuedit-trinity konqueror-nsplugins-trinity konqueror-trinity
  konsole-trinity kpager-trinity kpersonalizer-trinity ksmserver-trinity
  ksplash-trinity ksysguard-trinity ksysguardd-trinity ktip-trinity
  libkonq4-trinity q4os-base q4os-desktop q4os-keyrings q4os-sw-profiler-data
  q4os-swcentre-data q4os-welcome tdebase-data-trinity
  tdebase-runtime-data-common-trinity tdebase-tdeio-plugins-trinity
  tdebase-trinity tdebase-trinity-bin tdepasswd-trinity tdeprint-trinity
  tdm-trinity twin-trinity
35 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es mssen 27,4 MB an Archiven heruntergeladen werden.
Nach dieser Operation werden 520 kB Plattenplatz zus¦tzlich benutzt.
M￶chten Sie fortfahren? [J/n] J
Fehl http://q4os.org/q4repo/ q4os-1-0-cn/main q4os-base all 1.9.4-a1
Fehl http://q4os.org/q4repo/ q4os-1-0-cn/main q4os-welcome amd64 2.1.5-a2
Fehl http://q4os.org/q4repo/ q4os-1-0-cn/main q4os-sw-profiler-data all 1.5.3-a2
Fehl http://q4os.org/q4repo/ q4os-1-0-cn/main q4os-swcentre-data all 1.3.2-a1
Fehl http://q4os.org/qtderepo/ jessie/main libkonq4-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main tdebase-data-trinity all 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main kicker-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main tdebase-runtime-data-common-trinity all 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main tdebase-tdeio-plugins-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main tdebase-trinity-bin amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main tdm-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main kdesktop-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main kfind-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main kcontrol-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main konqueror-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main kappfinder-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main kate-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main tdepasswd-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main tdeprint-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main khelpcenter-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main klipper-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main kmenuedit-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main konqueror-nsplugins-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main konsole-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main kpager-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main kpersonalizer-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main twin-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main ksmserver-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main ksplash-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main ksysguardd-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main ksysguard-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main ktip-trinity amd64 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/qtderepo/ jessie/main tdebase-trinity all 4:14.0.1-0debian8.0.0+0.1
Fehl http://q4os.org/q4repo/ q4os-1-0-cn/main q4os-keyrings all 1.1.2-r1
Fehl http://q4os.org/q4repo/ q4os-1-0-cn/main q4os-desktop all 1.4.9-n1
E: Fehlschlag beim Holen von http://q4os.org/q4repo/pool/main/q/q4os-base/q4os-base_1.9.4-a1_all.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/q4repo/pool/main/q/q4os-welcome/q4os-welcome_2.1.5-a2_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/q4repo/pool/main/q/q4os-sw-profiler-data/q4os-sw-profiler-data_1.5.3-a2_all.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/q4repo/pool/main/q/q4os-swcentre-data/q4os-swcentre-data_1.3.2-a1_all.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/libkonq4-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/tdebase-data-trinity_14.0.1-0debian8.0.0+0.1_all.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/kicker-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/tdebase-runtime-data-common-trinity_14.0.1-0debian8.0.0+0.1_all.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/tdebase-tdeio-plugins-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/tdebase-trinity-bin_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/tdm-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/kdesktop-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/kfind-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/kcontrol-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/konqueror-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/kappfinder-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/kate-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/tdepasswd-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/tdeprint-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/khelpcenter-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/klipper-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/kmenuedit-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/konqueror-nsplugins-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/konsole-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/kpager-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/kpersonalizer-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/twin-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/ksmserver-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/ksplash-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/ksysguardd-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/ksysguard-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/ktip-trinity_14.0.1-0debian8.0.0+0.1_amd64.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/qtderepo/pool/main/t/tdebase-trinity/tdebase-trinity_14.0.1-0debian8.0.0+0.1_all.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/q4repo/pool/main/q/q4os-keyrings/q4os-keyrings_1.1.2-r1_all.deb  404  Not Found [IP: 81.95.96.231 80]
E: Fehlschlag beim Holen von http://q4os.org/q4repo/pool/main/q/q4os-desktop/q4os-desktop_1.4.9-n1_all.deb  404  Not Found [IP: 81.95.96.231 80]
E: Einige Archive konnten nicht heruntergeladen werden; vielleicht ᄏapt-get updateᆱ ausfhren oder mit ᄏ--fix-missingᆱ probieren?
#10 2016-11-22 13:48
It looks, for some reason, there is not Q4OS keyring installed. So add it in terminal:
$ wget -nv -O- http://q4os.org/q4repo/q4a-q4os.gpg.pub | sudo apt-key add -
In any case, please post a feedback, even on success.
#11 2016-11-22 14:02
judydudi
SUCCESS!
everthing was now updated and after re-login i was informed about ORION 1.8. update since last login.
Thanks a lot.
#12 2016-11-22 14:13
Thanks for the feedback, there was a Q4OS keyring update from 2048bit to more secure 4096bit keys about a year ago. This system probably kept the old Q4OS keyring. You can verify it this way:
$ sudo apt-key list
If you will see lines:
pub   2048R/E0E1D449 2012-06-19
uid                  q4ossystem (q4os) <q4os@q4os.org>
you can safely remove old Q4OS keyring this way:
$ sudo apt-key remove E0E1D449
#13 2016-11-22 15:17
judydudi
OK, i removed old one as you described. The new one is from 2016-03-25
pub   4096R/E2E6A0B3 2016-03-25
uid                  Q4OS APT archive (Q4OS APT signing key) <q4os@q4os.org>
#14 2016-11-22 15:28
Yes, now it's correct.
