#1 2016-10-10 03:55
wiko
Hi about scorpion
i am thinking to install scorpion (i understand is testing branch)  in another laptop;  but someone here is using this and feel is trusty to use in everyday common or daily use? i mean with no posibility of crash?
#2 2016-10-10 11:06
Re: Hi about scorpion
We don't recommend to use Scorpion for production machines in any case. You can use it on the daily basis, but keep in mind, you could meet more or less severe issues.
#3 2016-10-10 11:14
I do use Scorpion on quite a regular basis and the warning above will always apply to any distro which is used for testing, but I am very happy (so far) that it is running without issue for me.
#4 2016-10-10 15:36
wiko
Another question
1 .Are scorpion repositories different from Orion?
2. Can there be existing programs in the scorpion repositories do not present in Orion?  I ask because I am looking for a program audio recorder graphic ( no command line ) and perhaps other programs more up to date which may be (present) in the trial version scorpion but not in Orion. Or i am wrong?
#5 2016-10-10 15:41
1. Yes
2. Yes, the packages in the Scorpion repositories are newer versions of the same ones (and some more) and are currently being tested (and fixed) to become the next stable version. I use audacity (available in both repo's) for audio recording it is quite straight-forward to use. smile
