#1 2016-09-22 16:37
VLC Crashes
I am trying to watch a video using VLC and each time it just crashes out. I started from the command line and this is the output.
VLC media player 2.2.1 Terry Pratchett (Weatherwax) (revision 2.2.1-0-ga425c42)
[0000000001b9b718] pulse audio output error: PulseAudio server connection failure: Connection refused
[0000000001acd118] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory
[00007f87c0001268] xcb_xv vout display error: no available XVideo adaptor
LLVM ERROR: Cannot select: intrinsic %llvm.x86.sse41.pblendvb
Never had a problem with VLC before, so am thinking this could be either due to using newer kernel or newer hardware not fully supported yet???
#2 2016-09-22 16:56
Re: VLC Crashes
Not sure if I have done the right thing but I installed nvidia-vdpau-driver and it would appear to have solved the problem.
#3 2016-09-22 18:32
Re: VLC Crashes
Just a question, did you install proprietary NVIDIA driver before ?
#4 2016-09-22 18:44
Re: VLC Crashes
No, I hadn't installed any other drivers as everything seemed to be working, I googled about and read a similar problem and that was a suggestion, I still have errors but at least vlc stays open for me to see the video now. I will post the current error messages later (not in q4os at the moment).
EDIT:
here is the command line when I play a video now.
[0000000001555418] pulse audio output error: PulseAudio server connection failure: Connection refused
[000000000145b118] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
modprobe: ERROR: ../libkmod/libkmod-module.c:816 kmod_module_insert_module() could not find module by name='nvidia_current'
modprobe: ERROR: could not insert 'nvidia_current': Function not implemented
[00007f6a24001268] xcb_xv vout display error: no available XVideo adaptor
Xlib:  extension "GLX" missing on display ":0".
I don't need the nvidia driver as I have a Graphics:  Card: Intel Device 22b1 as reported by inxi but definately not nvidia. Should I remove that driver and install something else to fix this issue?
#5 2016-09-22 19:36
Re: VLC Crashes
I removed the nvidia driver and now the error messages are ...
[0000000000a4b418] pulse audio output error: PulseAudio server connection failure: Connection refused
[0000000000951118] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007f48e4001268] xcb_xv vout display error: no available XVideo adaptor
But the video plays, so it's working at least. I can't figure out why VLC wants the nvidia driver file though any ideas?
I checked using speccy in Win 10 and the graphics are just reported as Intel HD Graphics (Dell)
        Intel HD Graphics
            Manufacturer    Intel
            Model    HD Graphics
            Device ID    8086-22B1
            Revision    22
            Subvendor    Dell (1028)
            Current Performance Level    Level 0
            Driver version    10.18.15.4256
                Count of performance levels : 1
                    Level 1 - "Perf Level 0"
#6 2016-09-23 05:58
Re: VLC Crashes
Just an odd thought - did you by any chance bring your /.config/vlc over from your old machine?
What happens if you trash that folder and try again?
#7 2016-09-23 10:08
Re: VLC Crashes
@crosscourt
    I bought the laptop and Win10 came with it so I thought I would see how it functioned, I also have some friends who I support that have new machines so it will make it easier for me to help if I can see something working on my own system. And if I am totally honest it's a lot better than I was expecting, I have had no issues that my friends have had and it runs like a dream (I still can't believe I'm posting that comment!) but I did do a completely fresh install without all the accompanying software that you get with new pc's/laptops and I think that may have a lot to do with it. I am scheduled to do two Win10 reinstalls without the bloat for friends after they saw how responsive my system is. But I still multi-boot and Linux is the first boot option smile
@bin
    I didn't copy any config files over, but I will try removing that later and see how I get on I'm not on the laptop at the moment so can't try it just yet, and thanks for the suggestion smile
#8 2016-09-23 10:53
Re: VLC Crashes
@bin
    I tried removing the .config files for vlc and it had little (or no) effect but it was worth a try smile
I have noticed though I have no sound in my Orion system and am now wondering if I have a bad installation so will do another one later to test. My Scorpion system works fully with sound although I still get the errors on the command line
Scorpion errors:
VLC media player 2.2.4 Weatherwax (revision 2.2.3-37-g888b7e89)
[0000000000aea248] pulse audio output error: PulseAudio server connection failure: Connection refused
[00000000009ef148] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Failed to open VDPAU backend libvdpau_i965.so: cannot open shared object file: No such file or directory
QObject::~QObject: Timers cannot be stopped from another thread
Orion errors in post #5
#9 2016-09-23 12:10
Re: VLC Crashes
@Dai_trying
First of all, you could try to install and run 'vdpauinfo' utility:
$ sudo apt-get install vdpauinfo
$ vdpauinfo
Try to install packages below one-by-one, and test separate results.
- vdpau-va-driver
- mesa-vdpau-drivers
- libvdpau-va-gl1
- nvidia-vdpau-driver
Please report back.
#10 2016-09-23 12:41
Re: VLC Crashes
I had previously installed all those packages and still had the errors, but I have just finished a fresh install of Orion and have this time left the kernel as stable. This time I installed the basic desktop profile and after reboot I have the correct screen size and also working sound, however, vlc still fails, this is the output on this fresh install...
[0000000002405fa8] pulse audio output error: PulseAudio server connection failure: Connection refused
[00000000021e0118] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007fb410001268] xcb_xv vout display error: no available XVideo adaptor
Segmentation fault
I installed vdpauinfo and ran it in terminal and got this
display: :0   screen: 0
Error creating VDPAU device: 1
Bearing in mind that I do not have an Nvidia card to you still want me to try the packages you mentioned?
#11 2016-09-23 12:47
Re: VLC Crashes
Yes, please try to install these packages in the correct order and post back the result of vlc run and vdpauinfo for each particular package installed.
#12 2016-09-23 14:43
Re: VLC Crashes
Ok here goes WARNING LONG POST lol
Errors on installation (no extra packages)
[0000000000d48b98] pulse audio output error: PulseAudio server connection failure: Connection refused
[0000000000d1c118] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007fcf80001268] xcb_xv vout display error: no available XVideo adaptor
Segmentation fault
vdpauinfo
INSTALLED vdpau-va-driver
$ sudo apt-get install vdpau-va-driver
Reading package lists... Done
Building dependency tree
vdpau-va-driver is already the newest version.
vdpau-va-driver set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
NO CHANGE SO SKIPPED TESTING FILE
INSTALLED mesa-vdpau-drivers
$ sudo apt-get install mesa-vdpau-drivers
  mesa-vdpau-drivers
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,199 kB of archives.
After this operation, 4,003 kB of additional disk space will be used.
Get:1 http://ftp.debian.org/debian/ jessie/main mesa-vdpau-drivers amd64 10.3.2-1+deb8u1 [1,199 kB]
Fetched 1,199 kB in 0s (1,733 kB/s)
Selecting previously unselected package mesa-vdpau-drivers:amd64.
(Reading database ... 76584 files and directories currently installed.)
Preparing to unpack .../mesa-vdpau-drivers_10.3.2-1+deb8u1_amd64.deb ...
Unpacking mesa-vdpau-drivers:amd64 (10.3.2-1+deb8u1) ...
Setting up mesa-vdpau-drivers:amd64 (10.3.2-1+deb8u1) ...
Processing triggers for libc-bin (2.19-18+deb8u6) ...
VLC COMMAND LINE INFO
[000000000136eb98] pulse audio output error: PulseAudio server connection failure: Connection refused
[0000000001342118] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007f0114001268] xcb_xv vout display error: no available XVideo adaptor
Segmentation fault
VDPAUINFO
INSTALLED libvdpau-va-gl1
  libvdpau-va-gl1
Need to get 40.9 kB of archives.
After this operation, 163 kB of additional disk space will be used.
Get:1 http://ftp.debian.org/debian/ jessie/main libvdpau-va-gl1 amd64 0.3.4-2 [40.9 kB]
Fetched 40.9 kB in 0s (407 kB/s)
Selecting previously unselected package libvdpau-va-gl1:amd64.
(Reading database ... 76602 files and directories currently installed.)
Preparing to unpack .../libvdpau-va-gl1_0.3.4-2_amd64.deb ...
Unpacking libvdpau-va-gl1:amd64 (0.3.4-2) ...
Setting up libvdpau-va-gl1:amd64 (0.3.4-2) ...
[000000000106bb98] pulse audio output error: PulseAudio server connection failure: Connection refused
[000000000103f118] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007fe000001268] xcb_xv vout display error: no available XVideo adaptor
Segmentation fault
VDPAUINFO
INSTALLED nvidia-vdpau-driver
The following extra packages will be installed:
  dkms fakeroot gcc gcc-4.9 glx-alternative-mesa glx-alternative-nvidia glx-diversions libasan1 libcilkrts5 libegl1-nvidia libfakeroot
  libgcc-4.9-dev libgl1-nvidia-glx libgles1-nvidia libgles2-nvidia libjansson4 liblsan0 libnvidia-eglcore libnvidia-ml1 libubsan0
  libxnvctrl0 make nvidia-alternative nvidia-driver nvidia-driver-bin nvidia-installer-cleanup nvidia-kernel-common nvidia-kernel-dkms
  nvidia-modprobe nvidia-settings nvidia-support pkg-config xserver-xorg-video-nvidia
Suggested packages:
  gcc-multilib autoconf automake libtool flex bison gdb gcc-doc gcc-4.9-multilib gcc-4.9-doc gcc-4.9-locales libgcc1-dbg libgomp1-dbg
  libitm1-dbg libatomic1-dbg libasan1-dbg liblsan0-dbg libtsan0-dbg libubsan0-dbg libcilkrts5-dbg libquadmath0-dbg make-doc
Recommended packages:
  linux-image libgl1-nvidia-glx-i386
  nvidia-modprobe nvidia-settings nvidia-support nvidia-vdpau-driver pkg-config xserver-xorg-video-nvidia
0 upgraded, 34 newly installed, 0 to remove and 0 not upgraded.
Need to get 33.2 MB of archives.
After this operation, 168 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://ftp.debian.org/debian/ jessie/contrib nvidia-installer-cleanup amd64 20141201+1 [20.2 kB]
Get:2 http://ftp.debian.org/debian/ jessie/contrib glx-diversions amd64 0.5.1 [9,432 B]
Get:3 http://ftp.debian.org/debian/ jessie/main libasan1 amd64 4.9.2-10 [195 kB]
Get:4 http://ftp.debian.org/debian/ jessie/main libcilkrts5 amd64 4.9.2-10 [40.1 kB]
Get:5 http://ftp.debian.org/debian/ jessie/contrib glx-alternative-mesa amd64 0.5.1 [3,488 B]
Get:6 http://ftp.debian.org/debian/ jessie/contrib glx-alternative-nvidia amd64 0.5.1 [3,804 B]
Get:7 http://ftp.debian.org/debian/ jessie/contrib nvidia-modprobe amd64 340.46-1 [14.5 kB]
Get:8 http://ftp.debian.org/debian/ jessie/non-free nvidia-alternative amd64 340.96-1 [138 kB]
Get:9 http://ftp.debian.org/debian/ jessie/non-free libnvidia-eglcore amd64 340.96-1 [6,979 kB]
Get:10 http://ftp.debian.org/debian/ jessie/non-free libegl1-nvidia amd64 340.96-1 [288 kB]
Get:11 http://ftp.debian.org/debian/ jessie/contrib nvidia-support amd64 20141201+1 [22.2 kB]
Get:12 http://ftp.debian.org/debian/ jessie/non-free libgl1-nvidia-glx amd64 340.96-1 [7,462 kB]
Get:13 http://ftp.debian.org/debian/ jessie/non-free libgles1-nvidia amd64 340.96-1 [152 kB]
Get:14 http://ftp.debian.org/debian/ jessie/non-free libgles2-nvidia amd64 340.96-1 [155 kB]
Get:15 http://ftp.debian.org/debian/ jessie/main libjansson4 amd64 2.7-1+deb8u1 [34.1 kB]
Get:16 http://ftp.debian.org/debian/ jessie/main liblsan0 amd64 4.9.2-10 [92.8 kB]
Get:17 http://ftp.debian.org/debian/ jessie/non-free libnvidia-ml1 amd64 340.96-1 [416 kB]
Get:18 http://ftp.debian.org/debian/ jessie/main libubsan0 amd64 4.9.2-10 [82.4 kB]
Get:19 http://ftp.debian.org/debian/ jessie/non-free nvidia-driver-bin amd64 340.96-1 [216 kB]
Get:20 http://ftp.debian.org/debian/ jessie/non-free xserver-xorg-video-nvidia amd64 340.96-1 [2,671 kB]
Get:21 http://ftp.debian.org/debian/ jessie/non-free nvidia-vdpau-driver amd64 340.96-1 [974 kB]
Get:22 http://ftp.debian.org/debian/ jessie/main libgcc-4.9-dev amd64 4.9.2-10 [2,066 kB]
Get:23 http://ftp.debian.org/debian/ jessie/main gcc-4.9 amd64 4.9.2-10 [5,352 kB]
Get:24 http://ftp.debian.org/debian/ jessie/main gcc amd64 4:4.9.2-2 [5,136 B]
Get:25 http://ftp.debian.org/debian/ jessie/main make amd64 4.0-8.1 [349 kB]
Get:26 http://ftp.debian.org/debian/ jessie/main dkms all 2.2.0.3-2 [70.9 kB]
Get:27 http://ftp.debian.org/debian/ jessie/contrib nvidia-kernel-common amd64 20141201+1 [11.2 kB]
Get:28 http://ftp.debian.org/debian/ jessie/non-free nvidia-kernel-dkms amd64 340.96-1 [4,037 kB]
Get:29 http://ftp.debian.org/debian/ jessie/non-free nvidia-driver amd64 340.96-1 [422 kB]
Get:30 http://ftp.debian.org/debian/ jessie/main pkg-config amd64 0.28-1 [57.5 kB]
Get:31 http://ftp.debian.org/debian/ jessie/main libxnvctrl0 amd64 340.46-2 [20.7 kB]
Get:32 http://ftp.debian.org/debian/ jessie/contrib nvidia-settings amd64 340.46-2 [720 kB]
Get:33 http://ftp.debian.org/debian/ jessie/main libfakeroot amd64 1.20.2-1 [44.7 kB]
Get:34 http://ftp.debian.org/debian/ jessie/main fakeroot amd64 1.20.2-1 [84.7 kB]
Fetched 33.2 MB in 15s (2,130 kB/s)
Extracting templates from packages: 100%
Preconfiguring packages ...
Selecting previously unselected package nvidia-installer-cleanup.
(Reading database ... 76610 files and directories currently installed.)
Preparing to unpack .../nvidia-installer-cleanup_20141201+1_amd64.deb ...
Unpacking nvidia-installer-cleanup (20141201+1) ...
Setting up nvidia-installer-cleanup (20141201+1) ...
Selecting previously unselected package glx-diversions.
(Reading database ... 76618 files and directories currently installed.)
Preparing to unpack .../glx-diversions_0.5.1_amd64.deb ...
Unpacking glx-diversions (0.5.1) ...
Selecting previously unselected package libasan1:amd64.
Preparing to unpack .../libasan1_4.9.2-10_amd64.deb ...
Unpacking libasan1:amd64 (4.9.2-10) ...
Selecting previously unselected package libcilkrts5:amd64.
Preparing to unpack .../libcilkrts5_4.9.2-10_amd64.deb ...
Unpacking libcilkrts5:amd64 (4.9.2-10) ...
Selecting previously unselected package glx-alternative-mesa.
Preparing to unpack .../glx-alternative-mesa_0.5.1_amd64.deb ...
Unpacking glx-alternative-mesa (0.5.1) ...
Selecting previously unselected package glx-alternative-nvidia.
Preparing to unpack .../glx-alternative-nvidia_0.5.1_amd64.deb ...
Unpacking glx-alternative-nvidia (0.5.1) ...
Selecting previously unselected package nvidia-modprobe.
Preparing to unpack .../nvidia-modprobe_340.46-1_amd64.deb ...
Unpacking nvidia-modprobe (340.46-1) ...
Selecting previously unselected package nvidia-alternative.
Preparing to unpack .../nvidia-alternative_340.96-1_amd64.deb ...
Unpacking nvidia-alternative (340.96-1) ...
Selecting previously unselected package libnvidia-eglcore:amd64.
Preparing to unpack .../libnvidia-eglcore_340.96-1_amd64.deb ...
Unpacking libnvidia-eglcore:amd64 (340.96-1) ...
Selecting previously unselected package libegl1-nvidia:amd64.
Preparing to unpack .../libegl1-nvidia_340.96-1_amd64.deb ...
Unpacking libegl1-nvidia:amd64 (340.96-1) ...
Selecting previously unselected package nvidia-support.
Preparing to unpack .../nvidia-support_20141201+1_amd64.deb ...
Unpacking nvidia-support (20141201+1) ...
Selecting previously unselected package libgl1-nvidia-glx:amd64.
Preparing to unpack .../libgl1-nvidia-glx_340.96-1_amd64.deb ...
Unpacking libgl1-nvidia-glx:amd64 (340.96-1) ...
Selecting previously unselected package libgles1-nvidia:amd64.
Preparing to unpack .../libgles1-nvidia_340.96-1_amd64.deb ...
Unpacking libgles1-nvidia:amd64 (340.96-1) ...
Selecting previously unselected package libgles2-nvidia:amd64.
Preparing to unpack .../libgles2-nvidia_340.96-1_amd64.deb ...
Unpacking libgles2-nvidia:amd64 (340.96-1) ...
Selecting previously unselected package libjansson4:amd64.
Preparing to unpack .../libjansson4_2.7-1+deb8u1_amd64.deb ...
Unpacking libjansson4:amd64 (2.7-1+deb8u1) ...
Selecting previously unselected package liblsan0:amd64.
Preparing to unpack .../liblsan0_4.9.2-10_amd64.deb ...
Unpacking liblsan0:amd64 (4.9.2-10) ...
Selecting previously unselected package libnvidia-ml1:amd64.
Preparing to unpack .../libnvidia-ml1_340.96-1_amd64.deb ...
Unpacking libnvidia-ml1:amd64 (340.96-1) ...
Selecting previously unselected package libubsan0:amd64.
Preparing to unpack .../libubsan0_4.9.2-10_amd64.deb ...
Unpacking libubsan0:amd64 (4.9.2-10) ...
Selecting previously unselected package nvidia-driver-bin.
Preparing to unpack .../nvidia-driver-bin_340.96-1_amd64.deb ...
Unpacking nvidia-driver-bin (340.96-1) ...
Selecting previously unselected package xserver-xorg-video-nvidia.
Preparing to unpack .../xserver-xorg-video-nvidia_340.96-1_amd64.deb ...
Unpacking xserver-xorg-video-nvidia (340.96-1) ...
Selecting previously unselected package nvidia-vdpau-driver:amd64.
Preparing to unpack .../nvidia-vdpau-driver_340.96-1_amd64.deb ...
Unpacking nvidia-vdpau-driver:amd64 (340.96-1) ...
Selecting previously unselected package libgcc-4.9-dev:amd64.
Preparing to unpack .../libgcc-4.9-dev_4.9.2-10_amd64.deb ...
Unpacking libgcc-4.9-dev:amd64 (4.9.2-10) ...
Selecting previously unselected package gcc-4.9.
Preparing to unpack .../gcc-4.9_4.9.2-10_amd64.deb ...
Unpacking gcc-4.9 (4.9.2-10) ...
Selecting previously unselected package gcc.
Preparing to unpack .../gcc_4%3a4.9.2-2_amd64.deb ...
Unpacking gcc (4:4.9.2-2) ...
Selecting previously unselected package make.
Preparing to unpack .../make_4.0-8.1_amd64.deb ...
Unpacking make (4.0-8.1) ...
Selecting previously unselected package dkms.
Preparing to unpack .../dkms_2.2.0.3-2_all.deb ...
Unpacking dkms (2.2.0.3-2) ...
Selecting previously unselected package nvidia-kernel-common.
Preparing to unpack .../nvidia-kernel-common_20141201+1_amd64.deb ...
Unpacking nvidia-kernel-common (20141201+1) ...
Selecting previously unselected package nvidia-kernel-dkms.
Preparing to unpack .../nvidia-kernel-dkms_340.96-1_amd64.deb ...
Unpacking nvidia-kernel-dkms (340.96-1) ...
Selecting previously unselected package nvidia-driver.
Preparing to unpack .../nvidia-driver_340.96-1_amd64.deb ...
Unpacking nvidia-driver (340.96-1) ...
Selecting previously unselected package pkg-config.
Preparing to unpack .../pkg-config_0.28-1_amd64.deb ...
Unpacking pkg-config (0.28-1) ...
Selecting previously unselected package libxnvctrl0.
Preparing to unpack .../libxnvctrl0_340.46-2_amd64.deb ...
Unpacking libxnvctrl0 (340.46-2) ...
Selecting previously unselected package nvidia-settings.
Preparing to unpack .../nvidia-settings_340.46-2_amd64.deb ...
Unpacking nvidia-settings (340.46-2) ...
Selecting previously unselected package libfakeroot:amd64.
Preparing to unpack .../libfakeroot_1.20.2-1_amd64.deb ...
Unpacking libfakeroot:amd64 (1.20.2-1) ...
Selecting previously unselected package fakeroot.
Preparing to unpack .../fakeroot_1.20.2-1_amd64.deb ...
Unpacking fakeroot (1.20.2-1) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for desktop-file-utils (0.22-1) ...
Processing triggers for mime-support (3.58) ...
Processing triggers for systemd (215-17+deb8u5) ...
Setting up glx-diversions (0.5.1) ...
Adding 'diversion of /usr/lib/libGL.so to /usr/lib/mesa-diverted/libGL.so by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libGL.so to /usr/lib/mesa-diverted/i386-linux-gnu/libGL.so by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGL.so by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libGL.so to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGL.so by glx-diversions'
Adding 'diversion of /usr/lib/libGL.so.1 to /usr/lib/mesa-diverted/libGL.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1 to /usr/lib/mesa-diverted/i386-linux-gnu/libGL.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGL.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libGL.so.1 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGL.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/libGL.so.1.2 to /usr/lib/mesa-diverted/libGL.so.1.2 by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1.2 to /usr/lib/mesa-diverted/i386-linux-gnu/libGL.so.1.2 by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1.2 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGL.so.1.2 by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libGL.so.1.2 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGL.so.1.2 by glx-diversions'
Adding 'diversion of /usr/lib/libGL.so.1.2.0 to /usr/lib/mesa-diverted/libGL.so.1.2.0 by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1.2.0 to /usr/lib/mesa-diverted/i386-linux-gnu/libGL.so.1.2.0 by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1.2.0 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGL.so.1.2.0 by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libGL.so.1.2.0 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGL.so.1.2.0 by glx-diversions'
Adding 'diversion of /usr/lib/libEGL.so to /usr/lib/mesa-diverted/libEGL.so by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libEGL.so to /usr/lib/mesa-diverted/i386-linux-gnu/libEGL.so by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libEGL.so to /usr/lib/mesa-diverted/x86_64-linux-gnu/libEGL.so by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libEGL.so to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libEGL.so by glx-diversions'
Adding 'diversion of /usr/lib/libEGL.so.1 to /usr/lib/mesa-diverted/libEGL.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libEGL.so.1 to /usr/lib/mesa-diverted/i386-linux-gnu/libEGL.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libEGL.so.1 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libEGL.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libEGL.so.1 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libEGL.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/libEGL.so.1.0.0 to /usr/lib/mesa-diverted/libEGL.so.1.0.0 by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libEGL.so.1.0.0 to /usr/lib/mesa-diverted/i386-linux-gnu/libEGL.so.1.0.0 by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libEGL.so.1.0.0 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libEGL.so.1.0.0 by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libEGL.so.1.0.0 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libEGL.so.1.0.0 by glx-diversions'
Adding 'diversion of /usr/lib/libGLESv1_CM.so to /usr/lib/mesa-diverted/libGLESv1_CM.so by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libGLESv1_CM.so to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv1_CM.so by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv1_CM.so to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv1_CM.so by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv1_CM.so to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv1_CM.so by glx-diversions'
Adding 'diversion of /usr/lib/libGLESv1_CM.so.1 to /usr/lib/mesa-diverted/libGLESv1_CM.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libGLESv1_CM.so.1 to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv1_CM.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv1_CM.so.1 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv1_CM.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv1_CM.so.1 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv1_CM.so.1 by glx-diversions'
Adding 'diversion of /usr/lib/libGLESv1_CM.so.1.1.0 to /usr/lib/mesa-diverted/libGLESv1_CM.so.1.1.0 by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libGLESv1_CM.so.1.1.0 to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv1_CM.so.1.1.0 by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv1_CM.so.1.1.0 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv1_CM.so.1.1.0 by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv1_CM.so.1.1.0 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv1_CM.so.1.1.0 by glx-diversions'
Adding 'diversion of /usr/lib/libGLESv2.so to /usr/lib/mesa-diverted/libGLESv2.so by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libGLESv2.so to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv2.so by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv2.so to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv2.so by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv2.so to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv2.so by glx-diversions'
Adding 'diversion of /usr/lib/libGLESv2.so.2 to /usr/lib/mesa-diverted/libGLESv2.so.2 by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libGLESv2.so.2 to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv2.so.2 by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv2.so.2 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv2.so.2 by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv2.so.2 by glx-diversions'
Adding 'diversion of /usr/lib/libGLESv2.so.2.0.0 to /usr/lib/mesa-diverted/libGLESv2.so.2.0.0 by glx-diversions'
Adding 'diversion of /usr/lib/i386-linux-gnu/libGLESv2.so.2.0.0 to /usr/lib/mesa-diverted/i386-linux-gnu/libGLESv2.so.2.0.0 by glx-diversions'
Adding 'diversion of /usr/lib/x86_64-linux-gnu/libGLESv2.so.2.0.0 to /usr/lib/mesa-diverted/x86_64-linux-gnu/libGLESv2.so.2.0.0 by glx-diversions'
Adding 'diversion of /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2.0.0 to /usr/lib/mesa-diverted/arm-linux-gnueabihf/libGLESv2.so.2.0.0 by glx-diversions'
Setting up libasan1:amd64 (4.9.2-10) ...
Setting up libcilkrts5:amd64 (4.9.2-10) ...
Setting up glx-alternative-mesa (0.5.1) ...
update-alternatives: using /usr/lib/mesa-diverted to provide /usr/lib/glx (glx) in auto mode
Setting up glx-alternative-nvidia (0.5.1) ...
update-initramfs: deferring update (trigger activated)
Setting up nvidia-modprobe (340.46-1) ...
Setting up nvidia-alternative (340.96-1) ...
Setting up libnvidia-eglcore:amd64 (340.96-1) ...
Setting up nvidia-support (20141201+1) ...
Setting up libjansson4:amd64 (2.7-1+deb8u1) ...
Setting up liblsan0:amd64 (4.9.2-10) ...
Setting up libubsan0:amd64 (4.9.2-10) ...
Setting up libgcc-4.9-dev:amd64 (4.9.2-10) ...
Setting up gcc-4.9 (4.9.2-10) ...
Setting up gcc (4:4.9.2-2) ...
Setting up make (4.0-8.1) ...
Setting up dkms (2.2.0.3-2) ...
Setting up nvidia-kernel-common (20141201+1) ...
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Setting up pkg-config (0.28-1) ...
Setting up libxnvctrl0 (340.46-2) ...
Setting up libfakeroot:amd64 (1.20.2-1) ...
Setting up fakeroot (1.20.2-1) ...
Package configuration
                 ┌──────────────────────────────┤ Configuring xserver-xorg-video-nvidia ├───────────────────────────────┐
                 │ Manual configuration required to enable NVIDIA driver                                                │
                 │ The NVIDIA driver is not yet configured; it needs to be enabled in xorg.conf before it can be used.  │
                 │ Please see the package documentation for instructions.                                               │
                 │                                                <Ok>                                                  │
Setting up nvidia-driver (340.96-1) ...
Processing triggers for initramfs-tools (0.120+deb8u2) ...
update-initramfs: Generating /boot/initrd.img-3.16.0-4-amd64
VLC COMMAND LINE INFO (video does play with sound)
[0000000000abc1c8] pulse audio output error: PulseAudio server connection failure: Connection refused
[0000000000a90118] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
modprobe: ERROR: could not insert 'nvidia_current': No such device
[00007f6fd8001a28] xcb_xv vout display error: no available XVideo adaptor
[00007f6fd80077e8] glx gl error: cannot create GLX context
VDPAUINFO
REBOOTED SYSTEM
[000000000152f778] pulse audio output error: PulseAudio server connection failure: Connection refused
[0000000001456118] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00007fd5c4001268] xcb_xv vout display error: no available XVideo adaptor
VDPAUINFO
At the end of all this vlc does play the videos (with sound) but the error messages are shown in the console. I have not configured the nvidia driver in xorg.conf as I fear it would bork the system (as I don't have nvidia card).
Hope this helps
#13 2016-09-23 14:57
Re: VLC Crashes
Thanks, it helps, we will try to analyze the problem.
#14 2016-09-23 15:05
Re: VLC Crashes
Thanks guy, I have now (--purge) removed the following packages
- libvdpau-va-gl1
and vlc still plays videos with sound and gives the following as console output (after reboot)
[000000000173d848] pulse audio output error: PulseAudio server connection failure: Connection refused
[00000000018f13e8] dummy interface: using the dummy interface module...
[00007f60f8004ec8] xcb_xv vout display error: no available XVideo adaptor
[00007f60f8005158] xcb_window window error: X server failure
#15 2016-09-26 08:24
Re: VLC Crashes
Unrelated posts to this topic has been moved, they continues here http://www.q4os.org/forum/viewtopic.php?id=1069
Please, make your posts related to the original question to keep discussion helpful and clear.
#16 2016-09-27 19:13
olzeke51
Re: VLC Crashes
@Dai - what format is the video???  avi , mpeg, wmv!!!,
The journey is . . . the reward.
#17 2016-09-27 19:44
Re: VLC Crashes
The ones I used for testing were .mp4.
I have found what might be the problem though, I installed inxi and the output of inxi -G is this :-
           Display Server: X.Org 1.16.4 drivers: intel (unloaded: fbdev,vesa) Resolution: 1366x768@60.00hz
           GLX Renderer: N/A GLX Version: N/A
So I don't have a GLX renderer avaiable
On my other installation with the stable kernel the output is
           Display Server: X.Org 1.16.4 drivers: fbdev,intel (unloaded: vesa) Resolution: 1366x768@0.00hz
in Scorpion it is
Graphics:  Card: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller
           Display Server: X.Org 1.18.4 drivers: (unloaded: fbdev,vesa) Resolution: 1366x768@60.00hz
           GLX Renderer: Mesa DRI Intel HD Graphics 405 (Braswell) GLX Version: 3.0 Mesa 12.0.3
I will have to reboot into scorpion now to check VLC plays the video ok, but I suspect it will.
#18 2016-09-27 20:37
Re: VLC Crashes
As suspected it plays fine in Scorpion although it also complains about the libvdpau_i965.so not being found.
Anyone know how I can install/configure GLX renderer??
#19 2016-09-28 19:27
Re: VLC Crashes
Please try to run from both installations:
$ sudo apt-get install mesa-utils
$ glxinfo 2>&1 | gzip -f > glxinfo.gz
and attach the 'glxinfo.gz' file here to analyze.
You could also try to run:
$ glxgears
to view simple GLX rendering in action.
#20 2016-09-28 20:57
Re: VLC Crashes
Install 1 (3.16.0-4-amd64)
dai@q4os-desktop:~$ sudo apt-get install mesa-utils
mesa-utils is already the newest version.
mesa-utils set to manually installed.
dai@q4os-desktop:~$ glxinfo
name of display: :0
Error: couldn't find RGB GLX visual or fbconfig
dai@q4os-desktop:~$ glxgears
Error: couldn't get an RGB, Double-buffered visual
Install 2 (4.6.0-0.bpo.1-amd64)
name of display: :0
Exact same on both, I am guessing the kernel is not picking up the video card, and that's the problem but have no clue how to resolve... sad
Just for info I ran the glxinfo in Scorpion in case it can give you some information (file attached)
glxinfo.gz
#21 2016-09-29 10:41
Re: VLC Crashes
Please attach the '/var/log/Xorg.0.log' file here. You could also run 'reportq4' tool and attach generated file here, or send it to e-mail support@q4os.org to analyze.
#22 2016-09-29 11:36
Re: VLC Crashes
Reports sent vial email, Thank you.
#23 2016-09-29 13:30
Re: VLC Crashes
First try to switch the GLX provider to Mesa:
$ sudo update-alternatives --config glx
reboot
Try to run glx utils:
$ glxinfo
$ glxgears
Remove all nvidia components:
$ sudo apt-get autoremove libgl1-nvidia-glx glx-alternative-nvidia nvidia-alternative xserver-xorg-video-nvidia nvidia-settings nvidia-kernel-common nvidia-modprobe nvidia-kernel-dkms
#24 2016-09-29 14:38
Re: VLC Crashes
Ok, we are making headway, inxi -g reports this
           GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.5, 128 bits) GLX Version: 3.0 Mesa 10.3.2
glxgears fails and returns this error
glxinfo and qreport.tar.gz sent by email
#25 2016-10-02 12:18
Re: VLC Crashes
I have managed to solve this by using the 4.7 kernel and xserver-xorg-video-intel both from backports. I think it may be a case of using Scorpion for newer hardware compatibility but I will keep running this in Orion and see if everything else is ok.
