#1 2016-09-22 00:06
olzeke51
#53 Scorpion Firefox install error
Created ticket #53 on S/F - but the 'attach file' wasn't intuitive.
Here is what the Software Center installer window showed
see attachment:
Wine also has a failed dependency:
Reading package lists... 98%
Reading package lists... Done
N: Can't drop privileges for downloading as file '/tmp/tmp.4Nl1PHGCXf-q4appsetup/tmp-setup-repo/InRelease' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
W: The repository 'copy:/tmp/tmp.4Nl1PHGCXf-q4appsetup tmp-setup-repo/ Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Testing installation ... Done
Reading package lists... 100%
Building dependency tree
Reading state information... 0%
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
q4os-wine-layer : Depends: libwine-gecko-2.24 but it is not installable
E: Unable to correct problems, you have held broken packages.
The journey is . . . the reward.
#2 2016-09-22 08:07
Re: #53 Scorpion Firefox install error
It looks like you have mixed repositories, you seem to be using debian jessie-backports and it should be stretch-backports. Which after a little investigation does not appear to be useful. But you should never mix repositories see this
#3 2016-09-22 08:25
@olzeke51, Dai_trying
We can confirm, it is Q4OS Scorpion bug, as the installer tries to install Firefox from jessie-backports repositories. It's added into our buglist.
