#1 2016-09-19 09:52
Jerome
Outdated avconv
Sometimes I download TV programs from bbciplayer using youtube-dl, which although available in the repositories, doesn't work (you have to download the newer version from the youtube-dl site. https://rg3.github.io/youtube-dl/download.html).
However when playing back the mpeg-4 files the audio and video are out of sync. When starting to download a file, youtube-dl gives me this message:
WARNING: Your copy of avconv is outdated and unable to properly mux separate video and audio files, youtube-dl will download single file media. Update avconv to version 10-0 or newer to fix this.
avconv is part of the package libav-tools but I already have the newest version of this, so not sure how to fix the problem. Any help appreciated.
#2 2016-09-19 10:45
Re: Outdated avconv
Is that the backports version of libav-tools that you've got?
Other possibility would be to cobble together a working get-iplayer using these instructions -
https://squarepenguin.co.uk/downloads/debian/
Good luck
#3 2016-09-19 16:07
Jerome
Re: Outdated avconv
Hi bin,
Backports version? Excuse my ignorance but what does that mean?
#4 2016-09-19 16:20
Re: Outdated avconv
Backports are later packages from the upstream (less stable by comparison) debian system.
They are compiled to work with the current Jessie version.
This may help explain more
https://backports.debian.org/Instructions/
Backports are enabled via Synaptic>Repositories - you'll see a line showing jessie-backports in the distribution column.
To install the libav-tools you would do:-
sudo apt-get -t jessie-backports install libav-tools
However, having just done that it reports the installed version is the latest so that's a dead end :-)
Do you use VLC to play the downloaded files?
#5 2016-09-19 18:31
Jerome
Re: Outdated avconv
Thanks for the info which will useful for future reference.
No I put them onto a USB stick which I then plug into my TV.
