#1 2016-09-06 21:21
rafaelramos
"Screen Saver" configuration crash
Hello,
I noticed an issue error in version 1.6.1.1 for the Raspberry Pi 3.
In the Control Center > Appearance & Themes > Screen Saver, when I click it gives a crash and does not open the screen saver option...
#2 2016-09-06 22:22
rafaelramos
Re: "Screen Saver" configuration crash
I found a bug report about this in "TDE Bugzilla":
https://bugs.trinitydesktop.org/show_bug.cgi?id=740
So I installed the "kscreensaver" and "kdeartwork" packages, but it did not work, the crash continues...
sad
#3 2016-09-07 09:00
We can confirm the issue, it is added into our internal buglist. We are going to investigate it now, we will put a result here.
#4 2016-09-07 14:37
rafaelramos
Thank you, guys!
#5 2016-09-08 16:15
This issue looks more complex, it refers deep to the system to the GLX video acceleration. We are working on a patch at the time and let you know, when ready.
#6 2016-09-08 17:06
rafaelramos
Okay, I'll be watching.
Thank you for help!
Regards,
Rafael
#7 2016-09-10 06:58
Screensaver crash is now fixed. The new Q4OS Orion 1.6.1.2 for Raspberry Pi is immediately available for download. Current systems will be updated from repositories.
#8 2016-09-10 22:20
rafaelramos
Great, guys!
You are the best!
Monday morning I will make the download at work.
