#1 2016-09-06 22:39
Mr.Mark
Default Keyring
How can I eliminate the default keyring request when opening Chrome. This happened after the most recent update. I would just like to eliminate/disable it.
#2 2016-09-07 00:36
rafaelramos
Re: Default Keyring
Try Just click "OK" button, without value in the fields...
#3 2016-09-07 12:45
Re: Default Keyring
That does NOT working! I have this annoying window every time I start Chromium, and already removed tdewalletmanager-trinity, but it still appears every time even if I click cancel. That became after latest update. How to get rid of it?
Update: This window appears even when I open page without password fields in it, so I assume this is a bug.
#4 2016-09-07 13:31
Re: Default Keyring
It's about Chrome/Chromium issue described here - https://bugs.chromium.org/p/chromium/is … ?id=643189 . According to Chrome developers, the issue should be fixed in the next Chrome/Chromium revision 53.0.2785.98 during the next week.
If you want to fix it immediately, the only workaround is to run Chrome/Chromium with '--password-store=basic' commandline switch.
#5 2016-09-07 20:42
Re: Default Keyring
There is another quick workaround to disable the Chrome keyring dialog, you could remove 'gnome-keyring' package from your system:
$ sudo apt-get remove gnome-keyring
#6 2016-09-08 07:48
Re: Default Keyring
New Chrome revision 53.0.2785.101 is available in repositories. The issue should be resolved after the Chrome update and reboot. Please do report, if issue persists.
